Old 04-26-2012, 05:24 PM   #11 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by seantobin5 View Post
I'm a little OCD and I don't really like seeing and wires or velcro in my car.
Mine is mounted on the steering column, slightly closer than where hawk2100n put his. You might appreciate the fact that mounting it slightly more forward, on the column, means you can run the wire behind the gauge without seeing it hardly at all. I completely agree with the guys suggesting the gauge cluster. It's the safest and most effective location for a gauge you will check very often. That side vent you are considering really is a bit farther away than ideal. I tried other locations first. This is by far the best and safest.
Old 04-27-2012, 11:45 AM   #12 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I have mine on velcro on top of the dash above the gauges. It's as close to a heads-up display as possible. I can also easily reach the buttons around the wheel instead of through it.
Old 04-27-2012, 12:21 PM   #13 (permalink)
Civic HX - '98 Honda Civic HX
90 day: 42.53 mpg (US)
I think I'll put it on the steering column as California98Civic says since it hides the wire. I was debating putting it on top of the vent but I realized that I didn't want to drill any holes or have random pieces of metal sticking out or it which may ruin the dashboard of the car. Is the velcro pretty sturdy so it's stable whenever I press any buttons without worrying that it will just fall back or anything?
Old 07-05-2014, 03:12 PM   #14 (permalink)
wreck front - '98 honda civic hx
Steering column, but now I wish i would have mounted inside the cluster area.
Old 07-05-2014, 05:06 PM   #15 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
linked this thread to here:
http://ecomodder.com/forum/showthrea...eii-23306.html
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 12-07-2014, 03:27 PM   #16 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
mount above steering wheel
PaleMelanesian,
Are you still using the same mount, and how is the velcro holding up?
Old 12-08-2014, 09:17 AM   #17 (permalink)
Hypermiler
Wagons
I have a new car now, so no...
but the same velcro is on the same scangauge and holding up. The on-dash velcro I had to replace for the new car, but the gauge's side is still ok. Good stuff they include with the SG.
Old 12-23-2014, 04:58 AM   #18 (permalink)
+mpg=sweet
sokdo's Avatar
1996 Midori Civic dx - '96 honda civic dx
90 day: 37.92 mpg (US)
2000 Taffeta Civic cx - '00 honda civic cx
1994 Frost Civic si - '94 Honda Civic Si
2004 GPW S2000 - '04 Honda S2000
i hope my 96 can get to 60mpg's.... if not... it will be fun trying to get there
honda civic hx, scangauge ii
