Old 03-08-2008, 02:54 AM   #1 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Side View Mirror Downsize
Hello -
I am working on a side view mirror downsize. I got this bicycle handlebar mirror from REI :
Blackburn Multi Mirror
Here it is installed on my driver's side :
Front View
Here it is from inside. I have a round blind spot mirror on the inside too :
Small Mirror
Here you can see a tuft test with the normal passenger mirror. The two forward tufts are being "sucked into" the normal mirror :
Normal Mirror Tuft Test
With the small mirror, the lower forward tuft is lined up nicely. The upper forward tuft is pulled up, probably toward the front side window air deflectors. I need those to stop rain from getting into the car and to mitigate my "no AC" window crack.
Small Mirror Tuft Test
I won't install a downsized passenger side view mirror until I can solve this problem on the installation :
Mirror "triangular cover" Gap
This means rain can get into my door, .
I could remove my passenger side view mirror altogether, but I am partial to symmetry (my bad, ).
CarloSW2
American Solar Energy Society
Old 03-08-2008, 03:07 AM   #2 (permalink)
Peakster's Avatar
Red Jeep Patriot - '07 Jeep Patriot
90 day: 25.14 mpg (US)
Beige Ford Ranger - '95 Ford Ranger XLE
Very nice. I especially enjoy the tuft test images.
Old 03-08-2008, 11:27 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Nice job, Carlos!
What is causing the gap, the fact that the bike mirror has to fit in somehow?
Old 03-08-2008, 05:07 PM   #4 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
heat gun and some silicon will take care of that gap..
Old 03-08-2008, 06:43 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
SVOboy -
Originally Posted by SVOboy View Post
Nice job, Carlos!
The original triangular shape "wrapped over" that area. I am using a flat mudflap that I cut up, so there is no "over-wrap". There is also an interior volume to the traingular space. When I screw in the cover, it warps the mudflap out (concave). You can see I also have some foam in there to try to form a seal. What I would like to do is go to a pick-a-part, and find a driver's side rear-view mirror or a broken one I can salvage. Cut away the part that sticks out, make a smaller shape to cover it, and wa-la, a "clean" mod.
CarloSW2
Old 03-08-2008, 06:44 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Chris D. -
Do you mean a heat gun to "bend the triangle over"? If yes, I think I would want to do that with the mudflap/side view mirror cover off the car, because there's lots of rubber seals that could be damaged by the heat gun.
CarloSW2
Old 03-08-2008, 08:39 PM   #7 (permalink)
Who
UnderModded
Pablo - '07 Hyundai Santa Fe AWD
90 day: 23.62 mpg (US)
Love it!!! I hate modern barn door mirrors. I liked the ones that mounted at the top of the A pillar.
Old 03-08-2008, 08:47 PM   #8 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
Carlos Nice job. What are your driving impression with it? Also what are the deflectors for?
"Judge a person by their questions rather than their answers."
Old 03-08-2008, 11:25 PM   #9 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Lazarus -
They work, but they wobble a bit at freeway speeds. I think it is because the bicycle mirror stock is not designed for the higher MPH. Once the triangular cover is solid, I may beef it up and/or experiment with other mirrors at my leisure, .
In terms of impression, during the day it is fine. At night I am still getting used to it. But, here is my ace in the hole :
1970's style Convex Mirror from JC Whitney
As you can see, I can see it all coming :
ZERO Blind Spots
The deflectors were already in place before I became an Ecomodder :
When does having your windows down start to effect your mileage? Reply to Thread
Originally Posted by cfg83 View Post
Chris D. -
That's why I got them too. My Saturn was good at getting me wet on rainy days, but I liked the window open so that I could manage my window fogging up. I think they are a good compromise because they allow me to postpone the use of AC as long as possible in the summer. In the Good 'Ol Dayz, I used to drive with the windows down all the way on the freeway, but depending on my speed, I may have them open for that one inch that is covered by the vent visor, on up to 4 inches unless I am below "aerodynamic speeds", aka a traffic jam.
CarloSW2
Old 03-17-2008, 03:12 PM   #10 (permalink)
Green Rodder
Grease Beast - '92 Dodge D250 Standard
Econo-Beater DX - '92 Toyota Corolla DX
My truck still has vent windows. I have an extra set, I should drill them out and attach a small mirror to it.
Side mirror drag & effect on fuel economy - quantified MetroMPG Aerodynamics 179 11-10-2022 03:25 PM
Where to get multi-pane inside rear view mirror? MetroMPG Aerodynamics 15 08-06-2010 09:40 PM
Bicycle side view mirrors? cfg83 Aerodynamics 2 02-15-2008 11:54 AM
DIY - Wire Tuck SVOboy DIY / How-to 4 01-25-2008 02:14 AM
Video: Ditching the Side Mirrors Increases Fuel Economy Peakster Aerodynamics 6 12-05-2007 07:43 PM
