Old 04-12-2014, 10:26 PM   #261 (permalink)
What are you going to do for floorboards?
Duckboards like a Schwimmwagen?
Carpet over sound-deadening and rigid insulation?
Old 04-12-2014, 11:31 PM   #262 (permalink)
Christopher Jordan's Avatar
White Whale - '03 Chrysler Town & Country mini van all white
Originally Posted by HydroJim View Post
recycled road signs?
Now the car is even more green
Cool! Green is a fast color.
ID:	14870   Click image for larger version
ID:	14871   Click image for larger version
Old 04-13-2014, 05:51 AM   #263 (permalink)
And if you roll it in the dark, the reflective surface will be easy to spot.
Old 04-13-2014, 07:54 AM   #264 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
At what point will you apply some corrosion protection to the frame?
Old 04-13-2014, 08:13 AM   #265 (permalink)
Who needs fancy underbody neon anyways?
Old 04-13-2014, 08:48 AM   #266 (permalink)
The interior will be completely finished, floors and sides will be stick on sound deadening material, then hard backed dense fiberglass insulation, then thin plywood with carpet glued to the plywood.
I will probably clean up the frame and brush-roll on some black urethane paint, before the next welding session with my brother Thursday, with the exception of the paint which would just make welding more difficult.
I might roll some black paint over the bottom of the road signs eventually.
regards
Mech
The Following 3 Users Say Thank You to user removed For This Useful Post:
aerohead (04-19-2014), Cd (04-30-2014), freebeard (04-13-2014)
Old 04-17-2014, 04:49 PM   #267 (permalink)
Welded in 50 tabs today in 4 hours working with #3 brother. Should be enough to hold the floor, sides, engine harness, radiator, and fuel tank in place. I use speed nuts 6MM with phillips head 6 MM screws. That way I can use one screwdriver to remove just about everything. In other places, Ill drill and tap 10-32 holes in the frame and use countersunk flush face hex drive screws.
Sendler, now it's time to paint the frame which I plan on starting tomorrow (Friday) if my back calms down from today. Then the floor panels can go in permanently with the screws and adhesive sealer.
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
aerohead (04-19-2014), HHOTDI (05-13-2014)
Old 04-18-2014, 06:18 AM   #268 (permalink)
The Eastwood seam sealer works pretty well over primer, though you probably have something already. I used it on the inside patches on floorboards of an old mini. Felt the same a factory seam sealer when it hardened. And it was easy to work in between the overlap with a brush.
Old 04-29-2014, 10:14 PM   #269 (permalink)
Drilled all but 6 of the tabs, floors are completely installed except for paint, sealing and final installation. Next welding session will be the seat mounts and some more tabs for final assembly of the side panels. I painted the upper portion of the frame with a brush and rustoleum, will do the bottom before sealing and final floor panel installation.
regards
Mech
ID:	14941   Click image for larger version
ID:	14942   Click image for larger version
The Following 4 Users Say Thank You to user removed For This Useful Post:
aerohead (04-30-2014), Christ (05-20-2014), HHOTDI (05-04-2015), Xist (04-30-2014)
Old 04-30-2014, 08:27 AM   #270 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
How are you isolating the aluminum from the steel to prevent galvanic corrosion of those screws?
