Old 04-01-2010, 05:34 PM   #1 (permalink)
VW GOLF - '96 Volkwagen Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 Suzuki AE50 Style
Last 3: 70.4 mpg (US)
The German - '99 Mercedes W202 C200 Classic
90 day: 27.65 mpg (US)
Undertray / belly pan build - VW Golf MK3 1.9 Turbo Diesel
Today I set about starting my undertray build, I wanted to build and strengthen the tray before mounting it to the car for ease of removal.
I bought 4 large sheets of 2mm correx board (see pics below) with the intention of using a couple of layers to get the correct strength. Unfortunately the rigidity was awful so I had to strengthen the tray with some pieces of roofing plastic. You can see this in the picture as the ligher plastic.
The car has a front tray fitted from the factory (which I did a little correx repair work on this morning) so today I made the mid and rear sections. Because a MK3 Golf has a full width rear axle I had to build a separate rear section. You can see in the pictures how the tray is notched to allow movement of the suspension. You will also see that I have split the mid tray in half to allow the hot exhaust pipework to run down the centre un-covered.
The rear tray is a little longer than it needs to be as I will trim it once I have the correct angle for the "diffuser" part at the back. I think this will have to be spaced 20mm - 40mm below the bumper for optimum effect. It will also cover the exhaust back box as it will be cooler at the rear of the system.
I hope to have it fitted soon and put up some more pics, just a matter of fabricating some brackets to attach it to some convenient places under the car.
ID:	5884   Click image for larger version
ID:	5885   Click image for larger version
ID:	5886   Click image for larger version
ID:	5887   Click image for larger version
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
Old 04-01-2010, 06:34 PM   #2 (permalink)
downhill both ways
Toby's Avatar
Terceleporter - '96 Toyota Tercel STD
90 day: 52.6 mpg (US)
How did you cut your material? How did you lay out the cuts?
Old 04-02-2010, 04:00 AM   #3 (permalink)
Hi there,
Because the material is so thin I used a stanley knife. The sheets are almost exactly the width of the car so, I dragged a sheet under there and used a jack to hold it against the floor of the car. Then I just cut around the various suspension components and exhaust.
With the rear I did the same, I just had to keep in mind where I'd be attaching it to when I build some brackets. I also left it a few extra cm longer than I needed so I can choose a length at a later date.
Old 04-02-2010, 03:30 PM   #4 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Hi Sallen, Looks like a good start. I need to do this to my Golf. My Mk IV has a bunch of 15mm plastic plugs in the underbody. I keep staring up at these on my back trying to come up with a way to attach my belly pan without drilling into the sheet metal. Please post more photos as you progress and let us know if testing shows any improvement in mpg.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 04-02-2010, 06:18 PM   #5 (permalink)
Will do, I have the same plugs in the bottom of mine, have resisted the urge to tap screws into them tho...
I don't know about the MKIV but the MK3 has 5 holes down each side in the "lip" under the sill (the bit the jack locates into). I'm going to use these as mounting points for the outside edge of the tray via some tiny 90 degree brackets.
The front will be connected using brackets going to existing bolts for the wheel arch liner, and screwed to the trailing edge of the factory tray.
I think the inside edge nearest the exhaust will be bolted to existing bolts around the exhaust tunnel. Once I have brackets made I'l post pics of the setup. I'm aiming for the tray to be easily removable leaving minimal brackets in place under the car.
It's sweet that you have the TDI Golf though, it's easily 10% better FE than my IDI engine, and has loads more power and torque. That new bluemotion Golf is amazing though, 110hp and 75mpg!
Old 04-03-2010, 01:42 AM   #6 (permalink)
WannaBe
geeteethree's Avatar
16VT - '90 VW Golf GTI 16v
Polo TDI - '99 Volkswagen Polo CL TDI Estate
Diesel
90 day: 47.76 mpg (US)
Great work on the undertray so far, look forward to installation. Can I ask where you purchased the correx? I have yet to found any local stockists, and delivery costs are a factor for these big sheets.
Hope to undertake a similar project on my Polo TDI soon. Will the undertray cover the jacking points, or will these be left exposed?
Regards, Grant
Old 04-04-2010, 07:59 AM   #7 (permalink)
Hi there, I think the jacking points will be exposed enough to use the jack.
I got my correx style sheet from Travis Perkins builder's merchant. It is far thinner than sign writing correx, so it's better to make a frame from something and "skin" the tray with the correx.
Old 04-04-2010, 07:37 PM   #8 (permalink)
WannaBe
Diesel
Excellent, there is a branch local to me
One plan was to incorporate wheel "strakes" into the undertray, but they are ideally placed at exactly the same places as the jacking points Perhaps tyre spats and side skirt channelling will suffice; small sections hinged at the jacking points to allow the jack to slide under
Thanks, Grant
Old 04-05-2010, 05:21 AM   #9 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
I have no connection with these guys here but it might work:Blind rivet nuts - ACUMENT-GLOBAL-TECHNOLOGIES - Nut
I found a few at work the other day and thought i could get them to work in the existing holes in the chassis.
ollie
Old 04-10-2011, 02:52 PM   #10 (permalink)
Right... Finally got the bugger on!
I built some brackets and bolted them to the tray, then bolted all three panels under the car. I mostly used existing bolts for the exhaust etc to attach the brackets to.
At the rear I spaced the rear edge of the tray down from the bumper using long bolts and bits of copper pipe.
Because the tray covers the rear silencer (with a hole cut out for the exhaust pipe tip) I built a heat shield with a hammer, out of some scrap aluminum I had lying about. It separates the plasic from the silencer.
I've tested it to motorway speeds and nothing has fallen off yet...
Looking forward to results.
ID:	8101   Click image for larger version
ID:	8102   Click image for larger version
ID:	8103   Click image for larger version
ID:	8104   Click image for larger version
ID:	8106   Click image for larger version
ID:	8107   Click image for larger version
Metro undertray / belly pan MetroMPG Aerodynamics 47 03-13-2014 06:13 PM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 08:50 AM
Some small aero tweaks - VW Golf Mk3 1.9 Turbo Diesel sallen Aerodynamics 0 03-28-2010 08:33 AM
Mirror Swap - VW Golf MK3 1.9 Turbo Diesel sallen Aerodynamics 2 03-28-2010 06:34 AM
Wanted (1st gen VW turbo diesel) 3lr For Sale 19 10-28-2008 04:28 AM
