Old 06-09-2017, 12:17 PM   #11 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
Originally Posted by cowmeat View Post
Looks really clean!
Would you mind driving down here this weekend and doing my Volt?
You guys keep making my miss my Insight
You probably miss the Insight because it has character.
Old 06-09-2017, 12:27 PM   #12 (permalink)
Engine-Off-Coast
Natalya's Avatar
Oh I should mention an MPG advantage I'm going to have is that I know where to buy ethanol-free gas. Right now it's got 87 regular with 10% ethanol in it, but that changes as soon as I have to fill up again. I've only done like 400 miles though so it's still going to be a while. Hopefully next week?
The Following User Says Thank You to Natalya For This Useful Post:
teoman (10-28-2019)
Old 06-13-2017, 02:35 AM   #13 (permalink)
Engine-Off-Coast
Natalya's Avatar
Okay so on my Silver G1 I put three aero panels under the back. One of them was really huge compared to the other two. I still have the measurements so I could duplicate it.
But I'm wondering what I should do for max FE? Ecky for example put big sheets that go under the whole body of the car.
A thought was I could use coroplast I have left over from the Black G2 to recreate the old G1 pan. Then, because it attaches easily, I could do some ABA testing. A testing regimen would be like I accelerate to 10 mph then throw it in neutral and see how far the car goes before stopping. But aero drag is most prevalant at higher speeds. I could try like getting to 40 then at a certain point on a road I could throw it in neutral and see how far it travels before hitting like 25. But then I'd need to be going down this road quite a few times with no traffic there. I'd also need a suitable road.
Anyone have any ideas how I can test?
aerohead (11-06-2019)
Old 06-13-2017, 03:30 AM   #14 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
A full, complete belly pan would be the absolute best for mpgs. It would be even better if the rear departure angle is around 5 degrees.
You're in luck! I did aerodynamic coastdown testing with my Escort ZX2 a couple years back. I gotchu
Here's the link - BabyDiesel's Cd testing thread
I noticed that my pictures have broken links for some reason. I'll have that fixed in the morning for you. The charts and diagrams really help in figuring out what's going on.
Also, you will need higher speeds to accurately test the rear pan. I did my testing starting at 55 mph, which was actually low. Basjoos started his testing at 80 mph IIRC (same methodology I used too!)
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
Old 06-13-2017, 01:46 PM   #15 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
For the diffuser remember that the body type and the interaction of other modded features will matter. You have a hatch. Babydiesel, I think, might have a notchback. Depending on how precise you want to be, and whether you want to be sure of benefits and not losses, you might consult the below and experiment:
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
BabyDiesel (06-13-2017), Natalya (06-13-2017)
Old 06-13-2017, 03:18 PM   #16 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Gen-1 Insights
House of Tudor
Team Streamliner
California98Civic, that is the chart I wanted to post with my message, but I did not have it and had to make the 5* assumption based off memory. Thank you for posting it!
I actually drive a '00 Insight now sir
Past threads:
ZX2 modding thread
Old 06-13-2017, 11:51 PM   #17 (permalink)
Engine-Off-Coast
Natalya's Avatar
Okay so that chart is suggesting max benefit around 3° then, am I reading it correctly?
Old 06-14-2017, 12:48 AM   #18 (permalink)
Cyborg ECU
Yes. And notice too that anything from 2-4* is really pretty close to the same thing. So a little imprecision will not make a major difference. And, anyway, no matter what we do not have the equipment for precision. And even then, we also have difficulty knowing how a diffuser interacts with other aero mods or features on our cars that make it different than the models on this graphic. So I say, try for three and get close and it will probably be good enough for a benefit. I am no expert. But that's how I understand what gets taught here.
Natalya (06-14-2017)
Old 06-26-2017, 12:22 AM   #19 (permalink)
Engine-Off-Coast
Natalya's Avatar
Today I removed the read window wiper and its motor and I got the tires back up to 52 PSI.
I also temporarily removed the passenger seat since I know I won't have any passengers today or tomorrow lol.
Old 07-11-2017, 01:19 PM   #20 (permalink)
Engine-Off-Coast
Natalya's Avatar
Bridgestone Potenza RE92s at 60 PSI, 1 of them got shredded.
Yesterday I noticed one of my tires wasn't driving smooth. Like, it felt like a flat spot. I assumed a rock or something got stuck in the tread and was pushing funny, because there'd be a small bump bump bump as I rolled along.
Today I start on my way to work, feel it again, and stopped the car and checked. The driver's side front tire was kinda warped in one spot I'd never seen anything like it before. I figured, "Okay, I'll just get to work and order two new ones, and hope this one lasts a day or two before I get them."
Yeah that didn't pan out, the tire failed on the highway at about 55 mph on the way to work. I replaced it on the side of the road with the donut tire, but I noticed the tire never actually popped. Instead, a patch of the tread was ripped off where the deformation was.
Could this be caused by overinflation or old age? I don't know the age of the tires but I can check. I had all 4 at 60 PSI for about 1500 miles. I think I'll go back down, unless y'all think this had nothing to do with PSI. Tires might have been manufactured in 2010.
