Old 06-22-2014, 11:26 AM   #301 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Pictures are great !
FE is ... not up to the involvment shown by your tail ...
Old 08-12-2014, 11:46 AM   #302 (permalink)
Hyosung - '07 Hyosung gt250r
90 day: 55.49 mpg (US)
Burgman - '07 Burgman 650 k7
UPDATE: I finished the front end (except the door) out of .093 polycarbonate. Bending it wasn't easy as shown by the bubble on the windshield when I over did it ... will cut, and replace that section.
Note: The side rod will be part of the wind deflector frame. It will be a velcro on/off attachment made from the same Al. rod that is used in the frame. This will allow me to lane split and travel through canyons without getting blown over.
For comparison an un-modded Burgman
Any ideas on how to make the door or "side wind deflectors"?
The Following 2 Users Say Thank You to hyper-miler For This Useful Post:
aerohead (08-21-2014), SwamiSalami (08-05-2015)
Old 08-12-2014, 07:08 PM   #303 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
That's what I was thinking as well - sorry to say so.
It's down to the base vehicle I'd guess - those 650cc being overkill.
The Burgman is a BIG & heavy scooter too.
Covering it adds more weight, and makes it quite bulky too - large frontal area, and lots of side area making it more wind-sensitive.
Looking at Allert Jacobs' Honda, he's done a lot of work to cut down on frontal area.
Old 08-13-2014, 04:32 AM   #304 (permalink)
OldContinents
Also with CVT you can not really "mis-use" the engine or transmission on purpose to gain a few mpg.
The tail and stuff certainly boosted high speed mpg but it does not show in reasonable driving.
Old 08-13-2014, 11:14 PM   #305 (permalink)
The radius of the side panels has a lot to do with side wind load just as streamlining has to do with front CdA. As to door configurations the two that come to mind are the 'cupboard door' a la '65 Lincoln 4 door and the forward hinged 'pop top' cab over style.
Old 08-20-2014, 09:37 PM   #306 (permalink)
No, the Burgman 650 has a manual mode so you can manually shift into 6 preset radius "ratios". Earlier this year I got close to 60mpg with no mods just holding the speed around 50mph in Over Drive "gear" (1-5 + OD). check my fuelly.
The Following User Says Thank You to hyper-miler For This Useful Post:
Old 08-21-2014, 06:16 AM   #307 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
All these pieces are so angular. I am afraid your fuel consumption will be much worse.
Old 09-01-2014, 08:37 PM   #308 (permalink)
The results from the Utah Vetter Challenge run have been posted at craigvetter.com. Impressive ride by all participants.
The Following User Says Thank You to Grant-53 For This Useful Post:
jkv357 (09-03-2014)
Old 09-01-2014, 09:12 PM   #309 (permalink)
sendler's Avatar
298 MPGe for Terry's streamlined Zero motorcycle.
Old 09-02-2014, 11:47 PM   #310 (permalink)
Now he can match the cruise range of most touring bikes at 200 miles. My only question is how much to build one like his? I would guess at least $20,000 and in the same range as a Hayes diesel or a Honda Goldwing.
