01-13-2022, 11:44 PM
#21 (permalink)
Considering they are illegal in 90% of jurisdictions they must be better or the man wouldn’t ban them.
Certify as a 35ft R-license park model.
Gotta get in the market of converting spent stronger than steel windmill blades into building materials
I believe it was Victor Papanek's Design for the Real World: Human Ecology and Social Change that had a chapter titled Why You Can't Make A Piano From B-52 Wing Struts. The product has to be designed for reuse. His example was a Heineken bottle that could be reused as a glass brick.
https://inhabitat.com/files/wobo_5.jpg
01-14-2022, 10:05 AM
#22 (permalink)
The man doesn't care, it's the prejudicial nimby's that worry about "property values" that do, then whine excessively to the city officials until they get what they want. BTDTMO
Those blades are pretty much garbage, not worth even the recycling value of the salvage materials in them. Might be stronger than a 2x4 or a sheet of 1/2" mushboard, though. Sticking them together and making the subsequent structure waterproof would be expensive, getting them somewhere else would be supremely pricey, processing them onsite to fit standard shipping requires big exotic equipment like removing a middle apartment in a 20 story complex. They arent flat or straight to commercial standards anywhere.
Like JSH, my retirement plans were pretty much in place, lifestyle altered. Only thing I would do differently would be relocate to somewhere less covid infested. Couple of million more doesn't make me any difference, just leaves more for the kids to inherit.
01-14-2022, 01:55 PM
#23 (permalink)
home of the odd vehicles
No need to stick them to anything at 20’ wide by 30’+ long…
Just chop them into 30’+ sections and set them in a circle building a pilon house
Composite Blades are very high R value, fill vertical gaps with custom cut, wood, glass, transparent plastic, spray foam, cement, whatever your fancy, leave the roof with a high overhang, waterproofing no longer critical insulation only required in the gaps formed by the twisting spires.
Considering the full blades will support about 10 ton each in compression at the base (even at their reduced strength) there should be little issue using them in place of as you said 2x4’s except they are 10-40’ wide instead of 4”
If 10 ton isn’t enough they are hollow, run some long strips of rebar and fill with cement , the fiberglass blade skin is anywhere from r20-r60 depending on how thick and close to the base you are
Outdoor non-waterproof park enclosures would likely be well served by a polin structure with a roof.
My thought was set in the ground as pillons they would make excellent highway barriers and walls in place of that ugly ass Rotted brown crap that is along every city bound highway
01-14-2022, 04:53 PM
#24 (permalink)
01-14-2022, 04:56 PM
#25 (permalink)
You Must Construct Additional Pylons!
01-14-2022, 05:45 PM
#26 (permalink)
I DDG'd for a reference and found Tensegrity Wiki*. A reference for Tensegrity Mast
https://tensegritywiki.com/wiki/Mast
Imagine a Beowulf Cluster 'anti-prism-based spiral mast' of these.
*Hosted by Miraheze.org, along with apparently 5000 others. See https://en.everybodywiki.com/Miraheze Another of those backwaters of Internet?
01-15-2022, 10:17 AM
#27 (permalink)
How about 100 to even 300 + ft for the new ones? 20 years ago, the 1mw Zond turbines were 747 wing spans and what kind of saw has a 20ft by 10ft throat, cuts composite, steel, and whatever filler they use nowadays? Never saw a carbide tooth band saw. Maybe diamond grit.
My understanding is the brown crap is designed to destroy itself sequentially instead of presenting a solid impact like a solid concrete barrier. Something about energy dissipation. High energy destruction and composite construction don't play together well. Can you say high speed composite death rain?
01-15-2022, 10:57 AM
#28 (permalink)
Frickin' lasers.
01-15-2022, 11:12 AM
#29 (permalink)
What makes a "FRICKIN" different from a conventional laser? Depth of focus I assume. citation, please
01-15-2022, 11:31 AM
#30 (permalink)
There was a segment on the news where some crews reinforce the bolts attaching guard rails to the posts, but those are actually supposed to give way after a certain amount of force, and if they don't they could be catastrophic.
No high-speed composite death rain, more like hitting a solid concrete barrier.
However, that might be preferable to slowly going over a cliff.
Fun. I went to post that and it said
Your submission could not be processed because you have logged in since the previous page was loaded.
Please push the back button and reload the previous window.
I didn't have a back button!
I finally found it, right next to the Any key.
Here in Arizona we have a freaking astronaut for a senator. I don't know where I saw "Freaking astronaut," but now I feel compelled to mention it whenever it comes up.
