Old 01-08-2019, 12:36 PM   #31 (permalink)
Before overdrive transmissions were common, low final drives were used to help fuel economy. I had a V8 Chevrolet Monza with a 3 speed automatic and a 2.29 final drive. Shouldn't be too hard to find other applications like that to pull some parts from, if that's what one was up to.
Old 01-08-2019, 01:28 PM   #32 (permalink)
I think richmond gear has a 2.29 or a 2.50 but im not sure how interchangeable 8.8 internal stuff is.
Their web site sucks. Maybe I am wrong.
And sadly they seem to too. Called them got their tech support guys, was told there was never s lower gear than 308, I said really I already have a 2.75 for a 8.8.
Then after some more checking with other guys came back asking do I have a 28 or 31 splines axles, I say why?? They said the gears only fit one or the other.
And again other say other wise, a 8.8 gear set is a 8.8 gear set, the splines only matter with the carrier.
Oh well experts...old saying experts = ex=past tense pert= a drip under pressure. Seems true in this case.
Rich
Old 01-08-2019, 01:29 PM   #33 (permalink)
That can be a very helpful tip, now to figure out when ODs became common...
Thanks.
Rich
Old 01-08-2019, 01:38 PM   #34 (permalink)
Thanks.
Rich
I had a 54 Plymouth with an overdrive handle, but using that handle just let the car freewheel when coasting. No engine drag when off the accelerator. Don't know how it did that.
Old 01-08-2019, 01:58 PM   #35 (permalink)
I know very well about the old Borg Warner 3 speed with Overdrive, and the free wheeling feature.
You can read up on them here:
https://www.fordification.com/tech/overdrive.htm
Before the new 6/8/and now 10 gear automatics I was planing on putting one between a auto and the rear end, as they are two transmissions in one, the three speed and the OD. I had one on a 1956 Studebaker that I rigged to shift into OD on any gear, so I had a 6 speed.
I would use 3rd and 2nd as a low and high range selector and use the OD with any forward gear, so I would have all kinds of gears.
It was complex and tricky but it could have worked.
But a all in one auto seems a much easier idea.
Rich
Old 01-08-2019, 04:48 PM   #36 (permalink)
The sad thing (or) good thing is I have two of these old 3speed OD trannies.
Now IF only I could find parts or instructions on how to divorce the OD from the main housing and in so doing create a stand alone Over Drive that could them be mounted mid ships as a browny transmission. Say I would then have a 8 speed drive train, or a 5 speed with a double over drive.
Rich
Old 01-08-2019, 05:22 PM   #37 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Its gotten to the point for me if its not in a junkyard axle ready to go its probably not worth it. lol
Sad, but even with you spend 600$ getting gears installed they are very finicky and buzzy.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 01-08-2019, 05:45 PM   #38 (permalink)
I fear as much. I am planing on doing my own rear end rebuilding, I will take the time to make sure the gears are running true.
Rich
Old 01-08-2019, 06:14 PM   #39 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by gumby79 View Post
Ecky what's the name of the program/link you use for your graph. I've been looking for something like that.
This is the one I like most. It conveniently has a lot of Honda ratios built in:
https://www.zealautowerks.com/transcalc.php
Old 01-08-2019, 06:18 PM   #40 (permalink)
Each gear mesh adds drag. I don't know how much.
