02-11-2018, 08:07 PM
You know you drive a junker/jalopy when...
Click & Clack -- The Tappet Brothers -- had a good line on this topic:
"You know you drive a jalopy when you have to give special operating instructions to someone who wants to borrow your car."
And they gave some examples like: how you have to jiggle the shifter or the key a certain way to make it go in gear; or how a certain door only opens from the inside; or the heater fan only works on the highest speed setting, etc.
Here's mine:
With my winter beater 2000 Metro having some intermittent stalling-at-idle problems recently, I bypassed the clutch safety switch so that I had the option of moving the car a short distance using the starter motor in the event it stalled in traffic.
That's confirmation (one of many) that I drive a junker!
02-11-2018, 08:12 PM
You know you drive a junker when... you're male. Females always have the new stuff.
02-11-2018, 10:12 PM
When it breaks and you can actually fix it your self and it doesn't cost hundreds of dollars.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
02-11-2018, 11:33 PM
My driver's door responds best to gentle persuasion. Open the wind wing and flip the inside handle. Pull gently on the outside handle and trigger the latch if needed.
It broke down in traffic (first time in 15-20yrs) two weeks ago, but I fixed it with my bare hands, by draining the diesel fuel filter (since replaced) for a while.
02-12-2018, 12:53 AM
Too many cars
I know I drive a junker/jalopy when:
I look out the window at it.
the carpet is always wet.
I emptied the 4th can of expanding foam into the rust holes.
the CV joints keep getting louder.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
02-12-2018, 04:40 AM
Volvo-driving MachYeen
YKYDJJW when you instruct your friend how to get the Volvo in reverse without the gearbox crunching
YKYDJJW when you have to gently knock on the headlight relay sometimes when headlights suddenly turn off
YKYDJJW when you must often fill coolant because the hose leaks when cold
YKYDJJW the engine leaks oil and you just shrug because the engine will be swapped this year and well, the underbody won't at least rust
YKYDJJW you cross your fingers at the inspection
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
The Following User Says Thank You to Fingie For This Useful Post:
02-12-2018, 10:43 AM
'User name checks out.'
02-12-2018, 10:55 AM
ScanGauge <3
YKYDJJW when you have to park your car on level ground because the engine no longer has good enough compression to hold its spot on an incline. (And the parking brake is busted.)
Best tank (so far): 32 MPG
The Following User Says Thank You to ThermionicScott For This Useful Post:
02-12-2018, 12:54 PM
#9 (permalink)
Tinkerer
YKYDJJW your wipers only work when it’s dry, but if you hit the hood above the motor it starts working again. Also, it takes an extra batter and a boost from a running car to maybe get it to start.
02-12-2018, 02:17 PM
#10 (permalink)
Just the other way around for me. I think I'd have to get special operating instructions before trying to drive a lot of new cars.
And my vehicles all have active on-line owner sites, so they aren't jalopies, they're classics :-)
The Following 2 Users Say Thank You to jamesqf For This Useful Post:
