When you are happy to put on a flannel shirt rather than turn on the fan for heat/defrost!
Also when in somewhat dim light (daylight) you don't run any lights because A: you have plenty of reflective material on the back for freeway driving....B: your car is white so you KNOW people can see it, and C: even if somewhat foggy on the freeway; why have headlights on when you know you are the slowest car on the road. (only exception
would be if a busy, awkward onramp would come up for people needing to see you)
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
