Old 09-14-2013, 05:23 AM   #131 (permalink)
And an Audi R8:
Name:	AST Audi R8.JPG
The Following User Says Thank You to sgtlethargic For This Useful Post:
aerohead (09-14-2013)
Old 09-14-2013, 05:41 AM   #132 (permalink)
Hudson Hornet:
Name:	AST Hudson Hornet.JPG
The Following 3 Users Say Thank You to sgtlethargic For This Useful Post:
aerohead (09-14-2013), KamperBob (09-15-2013), mikeyjd (09-14-2013)
Old 09-14-2013, 12:20 PM   #133 (permalink)
Originally Posted by sgtlethargic View Post
An AST overlay that matches and a good looking car- Renault Dezir 2010 concept:
Well, this is one way to handle the rear window:
Old 09-14-2013, 01:15 PM   #134 (permalink)
Hudson
Hudson Hornet:
I just saw the 'Super 6' version of this car a week ago,west of where I live.
These Hudsons were the only 'buy recommendation' Dr.Kamm had for friends and associates in the 1950s.
Thanks for the image and comparison!
Old 09-14-2013, 01:18 PM   #135 (permalink)
window
The funny thing about the plan taper of a properly boat-tailed car,is that you don't need a rear window at all.Everything can be seen from the side mirrors.
user removed (09-14-2013)
Old 09-14-2013, 01:27 PM   #136 (permalink)
zero-point
On this Renault,we might want to slide the template back a bit,maybe inline with the door handle.
It will show that the roofline is a smidgeon 'fast.'
The 2nd-gen 'Template' might and probably will show a better fit.
I suspect that the boundary layer would like this car very much,as far as the roof anyway.
Thanks for image and comparison.
Old 09-14-2013, 01:35 PM   #137 (permalink)
pie-shaped
That being the case, a pie-shaped cut would broaden the range of usable hulls. OTOH, the Template is more like a pontoon.
I dare you to take two surfing short-boards, mount one on the top of the roll bar, cut the go-karts length out of the other one and fashion front and rear bumpers—and then tension trampoline netting into a hyperbolic paraboloid between the two. It would act like a tinted window, shed rain and the permeability would slow the air but equalize the various high and low pressures on the front, back and sides of a Tromphenwagen shape.
Do you even have a go-kart? It would be the safest one on the block.
That's exactly what I would do.
Or make a 'one-shot' mold which includes the allowance for the pie-cut and cast a lighter-weight shell inside that.
The caveat: If you have Femme-bots with goats,stay with the original heavy-wall boat hull.A goat can render a light shell fit for the landfill overnight!
Old 09-15-2013, 12:55 AM   #138 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
does this look correct or should it be moved forward/back??
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 09-15-2013, 02:06 AM   #139 (permalink)
I think that it is about right. It might be easier to tell with a larger image, but sometimes it is tricky to find the high point of the roof.
deejaaa (09-15-2013)
Old 09-15-2013, 03:20 PM   #140 (permalink)
Originally Posted by aerohead
The caveat: If you have Femme-bots with goats...
The funny thing is—I think I understand that.
deejaa -- there is a secondary use of the Template; where you slide it back and forth to align the [front and rear] wheels and transcribe the underside, for the spats and stuff.
Renault Dezir 2010 concept: I couldn't find a closeup of the backlight, but appears to be treated like this area on the front fender tops.
This suggests the backlight is perforated, not a bad strategy optically.
aerohead (10-11-2013), deejaaa (09-15-2013)
