Old 10-12-2011, 01:23 PM   #221 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
The GMC motor home chassis would make a great start for a fully aero pick-up. Put a diesel in it with a Toronado high ratio differential, coupled with the very low floor-bed height...hmmm? One could just about, directly copy the template for a body shape. Any one else thinking 30mpg+ with a i 1/2 ton capacity truck?
If Decoliner is Googled, there is a u-tube of the one talked about here, and a really cool Hot-rod version.
Old 10-12-2011, 02:20 PM   #222 (permalink)
90 day: 19.36 mpg (US)
GMC moho's were always plagued by poor traction. The weight balance tends to wind up on the non-driven axle pair. This might be "fixable" but the the GMC frame is also known for serious corrosion issues.
Old 10-12-2011, 03:22 PM   #223 (permalink)
Whitey - '10 Ford Ranger XL
Pickups
90 day: 33.74 mpg (US)
Hershey - '13 Nissan Altima SL
90 day: 28.68 mpg (US)
Midas - '10 Toyota Prius two
wouldn't a belly pan help out with the corrosion?
Check out my facebook page, if you feel like watching my progress.
http://www.facebook.com/pages/MPGran...007268?sk=wall
Old 10-12-2011, 11:22 PM   #224 (permalink)
CFECO
CFECO's Avatar
90 day: 29 mpg (US)
I never had a traction problem with my 76 Palm Beach, but I also did not drive it in the snow or much off the road, it sure had a great ride with the torsion bar and air suspension though. The corrosion could be solved easily I think if building a frame off pick-up conversion out of one of these machines, and a belly pan would block off a lot of corners on the frame to catch salt and moisture.
Old 10-25-2011, 10:20 AM   #225 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Today started to make my boattail and the evo1 version is already tested that it wont fall off. Its manufactured from 3mm thick black abs and drilled straight to rear hatch. Length is about 600mm or 24"
Angles used on the side tried to get 10 degrees and the roof according to template C. When I try to fit it to the template it is quite close IMO :/.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
blownb310 (02-27-2012)
Old 10-25-2011, 02:39 PM   #226 (permalink)
That looks devilish.
Old 10-27-2011, 02:25 PM   #227 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Yes, but if the previous owners in the past 30+ years hadn't done that it would be costly to fix.
But it would be cool to build a motor home from the ground up.
Old 02-08-2012, 06:53 PM   #228 (permalink)
Another 22-degree devotee
I scored a copy of 'AERODYNAMICS FOR NAVAL AVIATORS',by Hugh Harrison Hurt,Jr.,University of Southern California,Los Angeles,California,August,1959.
In the section on AIRFLOW SEPARATION,page 58,is Figure 1.26.'Airflow Separation (sheet 2 of 2),a photo,from Douglas(Aircraft Corp.)' Report NO. ES 29075,showing turbulent separation on a surface illustrated by reversed flow.
If you establish the centerline of the body of revolution being studied,then determine the tangent angle at the point of separation on the body you find it to be a 22-degree angle.
This is 1959.
W.A.Mair published his 'optimum' 22-degree boat tail report in 1968.
What is old,is older,and is new again!
The image is pretty grainy,but maybe Saturday Al can help me post it.
My aging Hippy neighbors claim that there was a fella every year at the Rainbow Gathering,who's answer to any question was,"22!" Perhaps he was onto something besides the acid.
Old 02-08-2012, 08:01 PM   #229 (permalink)
No, "42" is the answer to everything!
Old 02-08-2012, 09:59 PM   #230 (permalink)
Sven7's Avatar
One of your best posts, Frank.
Maximum angle for boat tail? abcdpeterson Aerodynamics 80 11-03-2021 12:55 PM
Aerodynamic Streamlining Template Part-B aerohead Aerodynamics 8 05-31-2013 12:23 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
Aerodynamic Streamlining Template: Part-A aerohead Aerodynamics 0 07-18-2009 02:37 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
