Old 09-06-2010, 04:35 AM   #51 (permalink)
That long tail is going to cause huge problems, mark my words!
Old 09-06-2010, 08:37 AM   #52 (permalink)
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
Well, the rear corners are actually not visible from the side mirrors
As far as increasing visibility, I believe I will put some very obvious LED lights on it, possibly get some lights that strobe a few times before they come on like motorcycles have. I will also put a yellow and black stripe pattern near the rear end.
Old 09-06-2010, 08:56 AM   #53 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Weather Spotter View Post
I would add more bracing diagonally in each square on the top.
I was going to say the exact same thing
1 diagonal brace per square should do the job.
Old 09-06-2010, 10:47 AM   #54 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Considering I keep seeing vehicles going down the road with hitch receiver totes on them, I think your extension doesn't really go beyond the limits of what's reasonable. It's about as long a tail as you'll ever see on a passenger vehicle, but only a foot or so longer than a receiver tote, or a power chair carrier.
Blaze orange, or bright arrest-me red, and add secondary lighting. You'll probably have to move the plate, too. This is just me, but I would be inclined to taper the tail in from the sides, as well as from top and bottom.
I remember my experience with an '86 Excel. It pinged almost constantly, unless I poured in a tankful of premium. I hated doing that and as I recall it actually did kill my mileage a little, but it also killed the knock. For the extra $1.25 per tankful, it was worth it. If your ride runs better on the rich stuff, then who am I to argue with that?
Old 09-06-2010, 02:54 PM   #55 (permalink)
What I'm worried about is how freaking long it is. It's going to hit stuff. Why don't you chop it in half and still get most of the benefit?
Also, you can buy reflective tape at Ace Hardware. I put the yellow stuff on a few spots of my Jeep to improve visibility when parked
Old 09-07-2010, 12:08 AM   #56 (permalink)
Could you provide a little more explanation to your opinion? I want to hear your opinion, but also what is behind it
Old 09-07-2010, 03:13 AM   #57 (permalink)
It's a really really long tail is what is behind my opinion. I can totally see it swinging out and hitting stuff, or someone running into it from the side.
The other thing is it has to be strong to actually work like it's supposed to. A shape like that is gonna have a lot of lift. Think of how strongly a spoiler has to be attached to a race car. Your tail is much bigger than a spoiler! I don't think there is any way those spindly aluminum beams are strong enough.
Old 09-07-2010, 07:26 PM   #58 (permalink)
Today I went and got a little more done, but not much. I put a license plate holder on and sprayed some primer on the joints. I'll have to see what kind of lights I can scrounge up then skin it.
Old 09-09-2010, 10:43 PM   #59 (permalink)
I sourced some shiny sheet metal and started on the lighting aspect of the aerocap. I made some parking lights (low light) from a piece of it, basically a rectangle bent about 150 degrees around a round bar. It has 11 LEDs in it, but they are diffused and terribly dim, so I may replace them with brighter ones, or just add more.
For the bright "filaments" I will use superbrights.
Also, the longer I think about it, the more I think I should narrow the back of this by more than a foot. I'm thinking 2 or 3 feet wide at the very back, to compensate for sticking out when I turn.
Old 09-10-2010, 12:20 PM   #60 (permalink)
Today I narrowed the back to a little shy of 3 feet wide, and started with the plastic sheeting. I didn't have a camera handy, so pictures will wait till later.
Aerocivic - how to drop your Cd from 0.31 to 0.17 basjoos Aerodynamics 802 05-15-2021 10:25 AM
Cousin scored a stereotypical "old lady's" car - 10 y/o Tercel, 3k miles. MetroMPG The Lounge 11 09-14-2010 10:21 AM
help W/ Remote Kill Switch Idea 93hatchDX DIY / How-to 21 07-31-2008 03:46 PM
