Here are the three digital gauges on the pillar to the left of the driver.
The top one is the water temp gauge. The sensor for it is in the bottom radiator hose so I can see the temperature of the water exiting the radiator. It lets me know when the water gets close to the 206 degrees that will turn on the fan. I do not want the power draw of this fan. So I can open the radiator shutter vent to lower the water temp. Also the red light next to the gauge also has an adjustable senor that turns the light on when the water gets to 185 degrees and tells me to start watching the water temp before it turns on the fan.
The second gauge is oil temp.
The bottom gauge is volts.
Next is the kill switch on top of the shifter knob
Last is a second MPGuino located on the dash in front of the passenger seat. This is what I use to help teach people that are interested in improving their MPG how to use a "Guido".
