03-12-2008, 08:23 PM
Albertan EV Builder
Hey Gang!
I just registered over on the diyelectriccar forums so figured I would join here as well.
I am changing my ways, getting rid of the s10 with the v8 so as to build an s10 with 144v!
Wish me luck
S.
03-12-2008, 08:30 PM
Dartmouth 2010
Sounds like a great project! Can you fill us in on the details?
Welcome to the site!
03-12-2008, 08:32 PM
If you tell us you are building an EV then you should already be well aware you need to furnish the forums with a build thread, update logs, and lots of pictures
Welcome to ecomodder and I look forward to hearing the projects progress.
03-12-2008, 09:15 PM
Welcome to the community.
03-12-2008, 09:56 PM
Hi sharp21 - welcome! I think you just wrote me a message from YouTube today, didn't you? Anyway - glad to see you here. Looking forward to another build thread.
-Darin
03-12-2008, 10:56 PM
Nope not me on YouTube... Unless my account got hacked!
As far as the project goes, its still in the planning / financing phase. I just sold my old ratrod volare, now I am trying to figure out the best thing to do with the s10. Its an 84 extended cab. Initially I was gonna pull the small block & sell that, then use the truck as my donor, but its an automatic which means I would need to swap in a manual. Not to mention there is a bunch of bodywork to be done & the interior is brown...
So now I am going to list it as is, but if it doesnt sell before I get home from work next month I will do the bodywork & primer it, then try to get some more $$$ out of it!
I figure the swap will be enough work without having to rebuild the whole vehicle!
S.
03-12-2008, 11:01 PM
Funny coincidence then - someone contacted me earlier today, interested in doing an S10 EV. I mentioned signing up here and at diyelectriccar.com
03-12-2008, 11:38 PM
EV test pilot
Keep us posted.
I have a small S10, with a 5-speed.
Part of the appeal of it was the idea of maybe converting it to electric.
I think I may end up using it to haul the Metro off to various car shows!
03-13-2008, 10:53 AM
#9 (permalink)
Master Novice
Schweet. Pull the bed and mount all the batts low, between and around the frame rails. It'd look stock - and the underside of the batt tray doubles as a belly pan!
Big ups for pulling the trigger. I can't make myself do it. My commute's too long, can't modify so much of the truck's carrying capacity away (I need the poundage capacity for firewood).
03-13-2008, 11:08 AM
#10 (permalink)
I couldn't have said it better.
