Old 10-11-2008, 09:28 PM   #1 (permalink)
88 comanche - '88 jeep comanche sport
another jeep to ecomodder
hello i am new to ecomodding, i have a 1988 jeep comanche 2.5l 4cyl. upon visiting this website has given me many ideas to boost my mpg.
so far:
vac guage
air fuel guage
injector shut down
alternator field shut down
elimination of manual fan
still not getting the mileage that i would like to, the most i have gotten so far is 25 mpg hwy
any ideas would be appreciated
Old 10-11-2008, 10:13 PM   #2 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
Welcome! Sounds like your well on your way. 25mpg is not too shabby. If you do a lot of highway aerodynamics is what you should check out.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 10-12-2008, 12:00 AM   #3 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Nissan Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Plymouth Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
Welcome. Fastplastic started up a nice jeep thread that you might want to check out...http://ecomodder.com/forum/showthrea...mods-2614.html
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 10-12-2008, 04:34 AM   #4 (permalink)
Red
Red's Avatar
Welcome to EM. Cool that you have an MJ, would love to have one. From the 4 poppers I've heard good things about an e-fan swap, also replacing the TB with on off a 4.0 seemed to help as well
Old 10-12-2008, 11:39 PM   #5 (permalink)
Taurus - '99 Ford Taurus SE
90 day: 17.89 mpg (US)
Windstar1 - '97 Ford Windstar Cargo
90 day: 16.99 mpg (US)
Vulcan - '97 Kawasaki Vulcan 750
90 day: 45.96 mpg (US)
Suzuki - '09 Suzuki SX4 Technology AWD
90 day: 24.62 mpg (US)
well 25mpg isnt too surprising being that its a light truck with a small engine.
but welcome! Ive always wanted a 4cyl jeep. but more of a wrangler instead.
Old 10-13-2008, 12:09 AM   #6 (permalink)
jeepin xj (pro jeep ecomodder/hypermiler) - '95 JEEP CHEROKEE XJ
Last 3: 21.58 mpg (US)
Hey Jeeps guys Justin here.
Question on those mods on the first guy how do i do it.
The injector kill switch, what does it do and how does it benefit
The alternator switch how do you do that
Its a 95 xj 2 door 4.0 liter OBD1
Old 10-13-2008, 03:31 PM   #7 (permalink)
you will probobly have to do the injection kill switch different than me because my jeep is an 88. what i did was put one wire on my map sensor to the wiring harness ground. i do not know how right that is but it worked on my truck, and would not suggest putting anything to ground on a newer vehicle. the only reason i had the guts was considiring the fact that i had a spare computer and a spare map sensor out of a 2.5 cherokee that i scrapped.
as for the alternator the only thing that i did was put a switch on the alternator field wire. if you are not familiar with how an alternator works you can go to HowStuffWorks - Learn How Everything Works! i have found alot of usefull knowledge there.
the only benefit to the alt not charging is , when the alternator field is turned off the alternator does not charge, therefore eliminating drag on the belt.
i use the injector shut down when i am going down hills and or down shifting to a stop. if you have an auto it will not be much use
Old 10-13-2008, 05:22 PM   #8 (permalink)
Yea i run hydrogen cell which draws 20 to 30 amps so i need my alternator that or 50 batteries. What is the injector switch it kills them i guess, then what you just use the key and re-fire it? why dont you just turn the car off and on with the key.
As for how i drive on hills if its a big enought hill i put in nuetral and shut her down. if its a short hill i just go to neutral and then back to drive and ease back into it. How bad is all this from trannies
Old 10-13-2008, 07:46 PM   #9 (permalink)
if you turn the key back too far it will lock your steering column and since you have an automatic you would have to stop your jeep because it may not start in drive. since i have a standard when i come to a stop sign i can cut my fuel injector and use the motor as a engine brake and not use any fuel, or i can shut down the engine and not risk locking my steering column. more of the less just a saftey and convienece issue.
Old 10-13-2008, 11:05 PM   #10 (permalink)
yea ive gotten used to just turning off and on real quick usaully never turning, plus if key is off all the way your miles dont register while hypermilling in nuetral must be on to get credit
Official EcoModder ScanGauge II group buy info MetroMPG Instrumentation 71 03-30-2010 07:48 PM
Honda element, vw beetle, jeep wrangler... hans2vt Introductions 9 05-08-2009 04:05 PM
'93 Jeep Cherokee - Weekend report DoctorP82 EcoModding Central 10 07-09-2008 10:53 PM
Hybridfest guy now at ecomodder ericbecky Introductions 9 03-21-2008 11:43 AM
Off-Road Test: '08 Jeep Grand Cherokee (Rally Race) RH77 The Lounge 4 02-25-2008 03:59 PM
