Old 01-07-2013, 01:12 AM   #291 (permalink)
Kinda reminds me of that new proto C-7 corvette the way the back window looks like that all covered up. Nice job, I dont think you can ask much more than that from a truck your getting what most do with cars !!!!
94 Geo Metro 52-56 MPG
06 Jetta TDI 46-48 MPG
The Following User Says Thank You to hotrodfeguy For This Useful Post:
MobilOne (11-11-2015)
Old 01-15-2013, 11:58 PM   #292 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Current aero cap configuration compared to the aero template...
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
Old 01-16-2013, 01:21 AM   #293 (permalink)
The Truck - '02 Nissan GU Patrol ST
Are you planning to flex rear lip down to match template, at a rough guess looks like there might be 4", maybe 10% of the height from the ground, would this translate in FE?
Old 01-16-2013, 01:36 AM   #294 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Here's what my tapered aero cap looks like from behind...
I don't have any plans in the near future to taper the last bit that sticks above the template. I can barely see out the back window in the current state. Dropping the back edge of the aero cap/hatch lower would make me blind back there and I'd have to install some cameras and monitors to see anything behind me. Installing a window on the hatch wouldn't provide me the visuals I require as the slope angle of the window would make it impossible to see clearly through. It's one of the compromises I need to make with my current aero cap state.
The overhang on the back is almost perfect when the hatch is up to provide a little extra shade over the tailgate when the tailgate is down.
I'm not sure how much effect the overhang has...I'm tempted to stick a Gurney flap on the end of the hatch and see what happens.
Old 01-16-2013, 03:34 AM   #295 (permalink)
Understand the whole rear visioin thing,
Although, I have rear decked out with a storage system for tools etc so internal mirror is blind, I only use side mirrors and take more care, go slower when reversing.
It does look tempting though, that's right where the template starts to angle more steeply, almost within reach of that little phantom tail on the tip.
Old 02-09-2013, 04:36 PM   #296 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Had this crazy idea of putting some extendable rails coming off the aero cap main rails fer a boat tail support.
To deploy them, I would pull the rails out and secure them.
Attach a framed boat tail and cover the frame with some flexible material (cloth) at that point and use my trailer light hook up fer any tail lights on the back end.
Move the license plate as needed.
I'll see what my brain can think up of...or any ideas y'all can come up with, too!
Thinking about doing the same thing fer extending my rear diffuser, too.
Old 02-09-2013, 06:26 PM   #297 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Had to address the tailgate seals today...
Formed a cap over the tailgate from some scrap metal stud. Screwed it in place using the screws from the tailgate protector.
Some zip ties through the cap and an aluminum bar provides the support to zip tie the seals. The zip ties holding the bar to the cap will be eventually replaced with pop rivets.
Flexible enough to not hurt you on the tailgate if yer sitting back there...
Left seal...
Right seal...
I might eventually build a new tailgate cap so it's the full width of the tailgate and pop rivet the aluminum bar just to cover the seals instead of having the aluminum bar all the way across the tailgate.
Old 02-09-2013, 08:57 PM   #298 (permalink)
The 'Vic - '96 Honda Civic DX
90 day: 39.3 mpg (US)
I think I may have spotted you in the wild. I-10 west approaching Pensacola some time ago (Dec or Jan). Gave the thumbs up. Maybe it wasn't you but there can't be too many T100 trucks with full aero caps and side skirts.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
The Following 2 Users Say Thank You to hawk2100n For This Useful Post:
BamZipPow (02-09-2013), MobilOne (11-11-2015)
Old 02-09-2013, 09:01 PM   #299 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Yup...that was me. It would've been January 3 (Thursday) evening. Sometimes I wonder how many people will end up sending me a bill to their chiropractor fer their neck twisting around to git a look.
Old 02-11-2013, 05:52 PM   #300 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Extendable boat tail framework. Just bar clamped fer piccies. It will slide in/out from the aero cap main rails and git pinned once they are extended.
The rear diffuser and rear skirts will be extended as well probably in the same manner. Thinking about using a reinforced mat as the skin...kinda like one of those summer blinds that can be rolled up and put away in the back of the truck bed.
We'll see how far I'll go with this. The hatch will still be functional with the boat tail on.
found another aero cap AeroAl Aerodynamics 5 05-19-2011 12:00 PM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
CLASS - 8 Truck Streamlining Benchmark aerohead Aerodynamics 0 02-28-2009 03:17 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
Yet Another Pickup Truck Aero Idea Big Dave Aerodynamics 14 05-03-2008 03:17 PM
