Old 10-30-2015, 12:50 PM   #361 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Looking at Post #345, I am taken how similar you cap looks to the black apparition I had on mine for a few years. See my avatar - its the last surviving picture of it.
The BZP cap has a better (shallower) angle and I whacked mine off at the tailgate. (I have a long truck and a short garage.) But both taper in the plan view, leading to smaller wake area. BZP's has to be lighter than mine. I used rubber matting for the skin and that demanded a sturdier structure.
My short and too-steep cap was the best MPG configuration I've had. BZP should do well with this one.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following 3 Users Say Thank You to Big Dave For This Useful Post:
aerohead (10-31-2015), BamZipPow (10-30-2015), MobilOne (11-12-2015)
Old 10-30-2015, 03:28 PM   #362 (permalink)
Backup lights or anti-tailgater?
Old 10-30-2015, 05:55 PM   #363 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
As I've been experimenting with my aero cap, I've studied the many different ones posted here in the forums and they have inspired the direction I've headed towards. Though my build will keep evolving, I will keep trying to learn from others so I can keep an open attitude on my builds. Thanks fer the inspiration!
It just so happens that the many "mistakes" I have in my aero cap has been a blessing when continuing the build with the boat tail. I didn't cut the aero cap off at the tail gate as I wasn't sure how short it should be. It turns out that the extended length was perfect fer attaching the canopy and side gap covers between the single wheel trailer and aero cap.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (10-31-2015), MobilOne (11-12-2015)
Old 10-30-2015, 06:02 PM   #364 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Back up lights and as utility lights since it will be hooked up on 3-way switches...one in the cab and one in the bed. No way would I even contemplate using them to keep someone from tailgating me. My Sparebumper device gives me ample protection from rear end collisions.
The Following User Says Thank You to BamZipPow For This Useful Post:
Old 11-05-2015, 01:20 PM   #365 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Finally took some time this morning to replace the luan side panels which were breaking down and probably wouldn't last very long this winter. The new panels were cut from FRP.
The Following 3 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (11-05-2015), MobilOne (11-12-2015), rumdog (11-06-2015)
Old 11-07-2015, 09:05 AM   #366 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
The Tyvek tape I used as seam protection isn't adhering to the FRP very well due to the bumpy texture of the surface. I will have to resort to a metal flashing and adhesive setup in order to keep water from intruding into the bed.
Looking at refining the aero cap some more by dropping the front vertical supports down a little so that the shape will be more in line with the cab instead of sticking up at the front corners. This will mean I will have to take the sides off so I can make that happen.
aerohead (11-07-2015), MobilOne (11-12-2015)
Old 11-07-2015, 12:36 PM   #367 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Hooked up the rear auxiliary lights with 3-way switches so now I will be able to see more behind me at a flip of the switch from either the cab or from the bed.
This will come in handy when I have to hook up or disconnect Dark Aero in the dark.
Old 11-10-2015, 06:08 PM   #368 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Back in black...
aerohead (11-10-2015), MobilOne (11-12-2015)
Old 11-10-2015, 06:21 PM   #369 (permalink)
black
"Step out of the truck sir! Your towel failed to conceal you license plate.'Should have used your 'hat'.!
We know where you live and we're keeping an eye on you!
Okay,we caught a whiff of your smoker.Can we be friends and eat over?
Lookin' naughty!
BamZipPow (11-10-2015), MobilOne (11-12-2015)
Old 12-03-2017, 09:03 PM   #370 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Wink
Got a new camera since the lens on the first one was fogged up from the UV rays. I also took this time to move the camera to the center of the hatch.
found another aero cap AeroAl Aerodynamics 5 05-19-2011 12:00 PM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
CLASS - 8 Truck Streamlining Benchmark aerohead Aerodynamics 0 02-28-2009 03:17 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
Yet Another Pickup Truck Aero Idea Big Dave Aerodynamics 14 05-03-2008 03:17 PM
