Old 04-03-2010, 05:23 PM   #31 (permalink)
recession proof rebel
k.civic.f4i's Avatar
that's what i thought. it was hard to the touch but i let it sit just to be sure. good info.
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
Old 04-04-2010, 02:00 AM   #32 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Buying waxed or unwaxed resin is one of those little details that can mess up the beginner. Carbon dioxide inhibits the cure of the esters, so sometimes we use some wax that floats to the surface to seal it off. This has to be cleaned off before anything else gets bonded on - one reason for the popularity of sanding. However, using unwaxed resin is real handy for adding layers gradually, and avoiding heat build-up and distortion on thick parts.
You can stock only unwaxed resin, and either add wax or just use plastic wrap, which can also help improve the surface, reducing finishing work.
When doing spot repairs, you can use a very quick "hot" mix, but eventually, the catalyst defeats itself if you use too much. It makes the dust toxic, too.
Engine/ECU mod ideas for mileage jcantara EcoModding Central 11 04-30-2010 05:22 PM
Requesting aero mod ideas (pickup: dodge ram 2500 4x4) nubbzcummins Aerodynamics 7 12-31-2009 12:41 AM
Testing the IAT mod tasdrouille General Efficiency Discussion 6 09-27-2009 04:09 PM
Mod ideas for Monte Carlo saunders1313 Aerodynamics 2 09-19-2008 09:24 AM
jeep aero mod ideas johnpr Aerodynamics 22 08-27-2008 07:45 PM
