Old 12-20-2016, 10:23 AM   #61 (permalink)
Applications | Counteract Balancing Beads
That says 5 oz, but 6 is probably close enough, I bought a $10 kitchen scale to use for weighing them.
Only weak spot on the HF that I've found is the 2 plate link on the bead breaker, I added a couple plates to make it into more of a shackle.
Old 12-21-2016, 11:23 AM   #62 (permalink)
I've never actually seen the hf tool, but it has to work easier than crow bars. Wood splitting wedge and a sledge hammer worked for bead breaking.
Old 12-21-2016, 06:04 PM   #63 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
I have the hf tire changer. I did some welding on it to make it stronger. It works real good. I have changed a ton of tires with it ranging from small car tires to 75 lb truck tires. It does them all. Use some lube and its a cake walk.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 12-21-2016, 06:52 PM   #64 (permalink)
Good to know. I too would beef it up a bit. You could save some money mounting and balancing yourself. It sounds like this method is superior to spin balancing and lead weight on the rim. I spend a lot of time in the mud and snow and the balance always seems off when you get on the highway. The stock rims on my late 90s dodge trucks have a nice pocket for dirt to collect. Sounds like the dynamic self balancing will be just what I need.
Old 12-21-2016, 07:27 PM   #65 (permalink)
Team Pontiac
The bb's are great, and will let you know if you have worn steering components, lol.
1991 F-250:
Old 12-21-2016, 08:01 PM   #66 (permalink)
My 98 has over 250k miles on it and definatly has some worn stearing components. It's slated for a front end rebuild soon. My 99 is still tight at 150k miles.
