Old 02-11-2011, 03:05 PM   #41 (permalink)
Enthusiastic EcoModder
Gnatmobile - '96 Geo Metro LSI
90 day: 44.68 mpg (US)
theRAV - '01 Toyota RAV4 NV
90 day: 21.07 mpg (US)
ACCELICA - '95 Toyota Celica GT Convertible
Last 3: 23.46 mpg (US)
The Van - '05 Chevrolet Uplander LS LWB
90 day: 21.04 mpg (US)
I see the difference now, the strapping looks quite a bit beefier.
Rock on on those gains, that's great!
Old 02-27-2011, 03:11 PM   #42 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Question for basjoos
A question for basjoos:
Originally Posted by basjoos View Post
5) How did you deal with the exhaust area? ...
Aluminum flashing covers the extire exhaust except for the underside of the muffler where I bring coroplast to within a inch of the muffler's surface.
I'm guessing that '92 Aerocivic exhaust is similar to my '97: Drops down behind the a/c condenser in front of the engine, and goes straight back from there. Mine has a slight jog towards passenger side approximately even with center of front wheels.
So aluminum flashing under the exhaust would run that whole length - right? Is the coroplast a full width sheet below the aluminum shield, or is the plastic cut with aluminum patched in to replace the plastic there?
Thanks basjoos! !
Coast long and prosper.
Old 02-27-2011, 09:14 PM   #43 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
The 92 Civic exhaust system runs down the center or the car, then jogs over to the right rear wheel well. The coroplast runs from the edge of the car to the edge of the exhaust tunnel, with the aluminum flashing spanning the tunnel. There are 3 pieces of coroplast under the car, right and left front, and then a piece that spans the full width of the car behind the exhaust jog. There are two pieces of aluminum flashing, one that runs from the front of the car to the exhaust curve, the 2nd piece runs from the exhaust curve to right rear wheel well.
Old 02-27-2011, 11:03 PM   #44 (permalink)
brucepick's Avatar
Gen-1 Insights
And is the center flashing strip anchored to the car itself? Or is it only fastened to the coroplast which is fastened to the car at the outer edges?
Old 03-01-2011, 10:23 PM   #45 (permalink)
brucepick's Avatar
Gen-1 Insights
(from pm from basjoos)
"The center flashing strip is anchored to the car through the coroplast. I install the coroplast sheets first and then unroll and attach the aluminum flashing on the top of the coroplast,drilling and tapping a new set of mounting holes through the coroplast into the car's frame."
Old 03-12-2011, 07:16 PM   #46 (permalink)
brucepick's Avatar
Gen-1 Insights
I started on it today.
Wifey already knows that's what I'm working on tomorrow (Sunday)!
Old 03-12-2011, 07:27 PM   #47 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Make sure you git piccies!
Old 03-12-2011, 07:39 PM   #48 (permalink)
brucepick's Avatar
Gen-1 Insights
Thanks for the encouragement, BamZipPow.
Pics - yes. Starting on that tomorrow a.m.
I'm started a new thread for the belly pan build.
http://ecomodder.com/forum/showthrea...tml#post225094
This thread has its own purpose - to show as much general info as possible on belly pan methods. Much of that is links to other threads, which is good, imho.
Old 06-09-2013, 08:59 AM   #49 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Bump. Because it's an excellent thread that has not been added to in two years and so is probably not familiar to lots of us. Several different designs linked or described here by members.
Last edited by California98Civic; 06-09-2013 at 11:56 AM.. Reason: typo "by" instead of "but"
Old 06-09-2013, 11:18 AM   #50 (permalink)
Thanks! I had seen a few of the individual build threads, but this is an excellent source of information, all in one place!
I think that it is the academic in me that feels that I need to reference everything. Please tell me if I need to stop!
In http://ecomodder.com/forum/showthrea...tml#post374773, I asked
Originally Posted by Diesel_Dave View Post
Had you not done the belly pan first, how well would it work to use your side skirts as the base for an undertray?
My belly pan doesn't go back as far as where the side skirts start. I think that is a definite posibility.
Also, I pointed out in http://ecomodder.com/forum/showthrea...tml#post373599
I was looking at Car MPG Efficiency Modifications Main - EcoModder and it says:
Belly pan / under tray 3.48%
3 user average
Front air dam 4.73%
3 user average
Three users is a very small sample size, but I expected a belly pan to be better than an air dam!
One idea that I had, although I imagine that this would be too much work, was to attach the head of a bolt to the underside of my car with JB Weld and then I just need to tighten a nut to attach the undertray, without drilling!
Would a nut be more likely to come loose than a screw?
What about cotter pins?
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Free belly pan in kansas city! lovemysan Aerodynamics 16 07-02-2010 10:22 PM
Air dam and belly pan wildfire8 Aerodynamics 2 05-01-2010 12:04 AM
Belly pan + Fan concept? meanderingthemaze Aerodynamics 13 02-08-2010 01:09 AM
