Old 11-23-2010, 09:53 AM   #31 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
I used ramps on the front end and a jack and jack stands to lift the rear of the Golf. I used a low profile rolling mechanic's creeper to slide around under there.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 02-08-2011, 01:55 AM   #32 (permalink)
Enthusiastic EcoModder
Gnatmobile - '96 Geo Metro LSI
90 day: 44.68 mpg (US)
theRAV - '01 Toyota RAV4 NV
90 day: 21.07 mpg (US)
ACCELICA - '95 Toyota Celica GT Convertible
Last 3: 23.46 mpg (US)
The Van - '05 Chevrolet Uplander LS LWB
90 day: 21.04 mpg (US)
This may be of help - not sure how to add it to wiki
Not sure how to add this to the wiki but I did a thorough belly pan how-to on:
http://ecomodder.com/forum/showthrea...tml#post219175
for the Metro today. Cost about $7, took 3 hours. I used jack stands because I didn't have ramps but then was glad I did because it allowed me to lay the whole sheet of coreplast under the wheels for the initial shaping.
I did not have to build a frame and feel good about the not crazy amount of holes I had to drill.
Old 02-08-2011, 05:17 AM   #33 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Only 3 hours ? That's quick
Old 02-08-2011, 11:15 AM   #34 (permalink)
Thanks, yeah I was stoked to see it go so quickly. I was prepared for a much harder time than I had. I think I just accidentally stumbled on a good method for doing it and mounting points happened to be easy. Also by cutting generously and trimming down it saved me the trouble of making templates.
Now I just have to decide if today I want to do the other 2/3s of the belly pan or make a camback. Hmm
Old 02-10-2011, 10:49 PM   #35 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
WOW! I can't even figure out a set of brackets in that much time. I've got 20 feet to cover though...
Old 02-11-2011, 02:25 AM   #36 (permalink)
darcane's Avatar
Here's my thread:
http://ecomodder.com/forum/showthrea...ado-11135.html
The links are temporarily down, so I attached them here. The framework is steel strapping from Homey Depot (just steel strips with holes). It is fastened with 1/4-20 screws, fender washers, and spring nuts.
I did the first version of my grill block and partial belly pan at the same time and saw a 3.5% improvement (no A-B-A, but I compared data with as few changed variables as possible).
Mike
ID:	7803   Click image for larger version
ID:	7804   Click image for larger version
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 02-11-2011, 11:58 AM   #37 (permalink)
Originally Posted by darcane View Post
Here's my thread:
That looks really good mike. I think that steel strapping is called plumbers tape. I have a roll of it that I keep around the boat for securing large hoses or wires in the bilge. I'll keep that in mind if I have to do any framing around the rear when I make it into a complete belly pan. Nice gains man, that's really good.
I obviously see the benefit in true A-B-A testing for proving the affect of each mod but half of me thinks tank-tank is just as important. If it helps you tank to tank then it definitely is saving you real and measurable $. Obviously it's subjective and will vary with the conditions and driving you subject it to with each tank so there are lots of factors but I still like seeing my miles go up and my gallons go down at the pump every time I slap some aluminum, screws, and plastic on my car
Old 02-11-2011, 12:35 PM   #38 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
when i put the belly pan on my jeep i'll be using a jack and jackstands, mainly so that i'm keeping in mind where the jacking points are and where the stands go
Old 02-11-2011, 12:41 PM   #39 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Just finished scanning this thread and wandering off into several of the linked threads as well. Nice work! I love how some folks painstakingly shape every inch while others more or less just "git 'er done" by whatever means.
I bought an aftermarket front undertray for my Fit shortly after I bought the car. It helped gas mileage incrementally, but the biggest improvement by far is that the car no longer gets pushed around by the airflow coming off semis or by high winds in general. Before the undertray the car was kinda squirrely in those conditions, no question about it. Now it's far more stable. Win-win.
My next under-car foray will be a rear diffuser. Nobody makes one so I'll have to fabricate, so thanks everyone for the tips and pics. I hope to have the same thing happen; better stability at speed, plus MPG improvement.
Old 02-11-2011, 01:55 PM   #40 (permalink)
darcane's Avatar
Mine is actually thicker than the rolls the plumbers use. I think it's still called strapping, but it's... maybe 1/8" thick? Thin enough you can bend it, but rigid enough that it will hold the weight of the corex sheet without sagging. I like this stuff since it makes a good frame work and the spring nuts just snap on so I can bolt it together without having to get a wrench on the backside.
Plumber's strapping is mostly intended for holding a verticle load. I don't believe it would work they way I built this frame.
Between aero tweaks, other simple mods, and driver re-education I've gotten my mileage from 15mpg combined to ~20mpg combined in my normal commuting.
Mike
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Honda Fit Belly Pan Project Fit Aerodynamics 17 08-10-2015 08:29 AM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Free belly pan in kansas city! lovemysan Aerodynamics 16 07-02-2010 10:22 PM
Air dam and belly pan wildfire8 Aerodynamics 2 05-01-2010 12:04 AM
Belly pan + Fan concept? meanderingthemaze Aerodynamics 13 02-08-2010 01:09 AM
