Old 01-13-2009, 08:08 PM   #891 (permalink)
Do you have an EV Album entry? (Sorry if I just missed it.)
It's a 1996 Honda Civic LX EV.
David Harrington's 1996 Honda Civic
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
Old 01-13-2009, 08:23 PM   #892 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
TheSCG has been holding out on us! He's got a blog!
Civic Electric Car Conversion
Come on, man. Share the love!!!
Glad to hear you passed inspection recently. Mine was fun once I figured out the correct legal hoops to jump through!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-13-2009, 08:30 PM   #893 (permalink)
Christopher Jordan's Avatar
White Whale - '03 Chrysler Town & Country mini van all white
I imagine many of us do! Amazing how many times I think "Hmm..... I saw that vehicle on Ecomodder!"
Old 01-13-2009, 09:37 PM   #894 (permalink)
My inspection was also entertaining, but not nearly as much of a journey as yours. The station was only 3 miles from my house! Though I was afraid of failing because my entire engine compartment consists of temporary brackets and my vacuum pump, control box, tray, controller are all held in place with tie wraps.
I think my next step is finishing under the hood. A stronger motor mount, install the 1.5 HP motor for the Power Steering and A/C compressor, and get a nice aluminum plate to mount the control systems to.
Old 01-13-2009, 10:35 PM   #895 (permalink)
90 day: 51.82 mpg (US)
96v car for $3k? Nice work!
Old 01-14-2009, 09:25 AM   #896 (permalink)
Indeed, very nice work.
Old 01-14-2009, 11:36 AM   #897 (permalink)
Thanks! It took a while to collect the parts, but it sure is fun building EVs!
Old 01-14-2009, 02:08 PM   #898 (permalink)
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Oldsmobile Intrigue GX
Last 3: 25.94 mpg (US)
Do a thread!!!
Hey SGC, you ought to do a thread over here. You have a lot of pics and text already, which will transfer over without a lot of the work usually needed. Then we'd have another car with which to compare how well the different voltages and setups work!
< And now, back to Ben! >
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
Old 01-15-2009, 02:01 PM   #899 (permalink)
I gave in an started a thread.
Ben- What gears are you using at what speeds? I am curious about your AMP draws at different speeds and gears.
Old 01-15-2009, 07:38 PM   #900 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Mostly been using 2nd and third gear.
I use 2nd up to 25 mph or so and then 3rd above that.
Here's a video made a while back testing acceleration in a couple different gears - no shifting - just put it in gear and go.
This was pretty much flooring it, meaning I was using all amps I had.
My controller is a 400 amp peak, but my ammeter only goes up to 300, and I've never really had a way to check how much I really can pull out of the controller or not.
For example, there is an adjustment (by screwdriver) in the controller to limit current. I don't even know for sure if that is all the way up or not.
I do know that the ammeter goes up a lot faster in a higher gear while accelerating than in a lower gear.
EDIT: Link won't work right - here's the video directly.
My YouTube Videos
electric car, electro metro, geo, metro
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 11:08 AM
Daox's 1997 Paseo Build Thread Daox EcoModding Central 241 11-12-2013 11:23 PM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 04:31 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 01:23 PM
