02-12-2009, 10:47 PM
So what's on your scangauge?
Just curious what others generally keep running on their scangauge. Personally, I have the trip mpg (xgauge), mph, instant mpg, and gph.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
02-14-2009, 11:47 PM
SLOLANE - '08 Chevy (Daewoo) Aveo5 SV 90 day: 30.55 mpg (US)
wrong thread.
02-19-2009, 07:08 PM
OCD Master EcoModder
TPS - - - - MPG
LBN - - - - aFE
TPS is critical to helping the car stay in lean burn. Has to be <20 to go in. Anything over 31, and it will go out of LB.
aFE is Average Fuel Economy for the current trip. It's an X-Gauge setting based on the avg mpg for current trip. The manual tells how to set up that one.
LBN is Lean Burn, for my Civic HX. Below is the setup for that gauge. I got the setup from a post by MrChoi on another board.
Use the code below to monitor lean burn with the Scan Gauge II.
To Monitor Lean Burn, type in:
TXD 686AF10115
RXF 044105150000
RXD 2808
MTH 000100020000
NAM LBN
and save.
If the value for LBN = 0 you are in lean burn.
If the value is higher than zero, you are not in lean burn.
Coast long and prosper.
02-24-2009, 12:00 AM
In hypermiler central
MPH fWT
MPG LOD
I like the MPH readout because my speedo only shows increments of 2. Water Temp is useful because I'm experimenting with grill blocks, and I want to make sure my engine doesn't warm up enough to trigger the fan. It's always fun to have the current mpg.
LOD is my favorite display; it's perfect for DWL.
02-25-2009, 10:55 PM
Left Lane Ecodriver
Trip gallons used (that's the quantity I try to minimize), trip mpg, °FwT so I know when to turn on the heater.
02-25-2009, 11:27 PM
- ATF temp
- water temp since the factory gauge is just a blank needle ("if it's over there, it's cold... if it's somewhere in the middle it's OK, if it's over there by the red part it's hot" )
- don't particularly care
02-26-2009, 07:27 AM
I use my GPH as an approximation of DWL. I use it as a way to ensure a "steady foot" driving technique.
Shovel: Why do you use the ATF temp? Even though it does affect FE, it seems like it would be something you can't directly control.
02-26-2009, 10:43 AM
I don't use scangauge as a fuel efficiency tool... but I do use my truck for "very rough service" in Arizona - and transmissions are expensive. When the trans fluid is over ~210 or so, I stop & idle (only happens on long/steep inclines now that a large aux. cooler is fitted) - the factory equipped warning lamp only illuminates when trans temp exceeds 290F - juice doesn't last long at that kind of temp
02-28-2009, 08:38 AM
#9 (permalink)
Lately I've been showing water temp in lower right corner.
Don't want to run hot in warmer weather. I put the grill block on during winter so I don't know exactly what effect it will have in warmer weather.
02-28-2009, 03:22 PM
#10 (permalink)
Average Gas Mileage --- Water Temp (F)
Instant mileage --------- Throttle position
