12-01-2010, 12:26 AM
#21 (permalink)
Originally Posted by Sulfuric
I'm at 60ish psi now. Of course, I have bridgestone ecopia ep-100s, and bridgestone tires seem to be relatively high quality. Unless your tire is damaged you shouldn't have problems until well over 100 psi.
I haven't come close to 100, but I was around 75 a few weeks ago on my tires (I should look them up to see what they are) by accident because I was using a gas station filler and didn't check. I got my bike pump and discovered my front tires were above 70 and lowered them. I think I'm currently around 65/60 front/back. I want to check again, though, since it's been ridiculously cold lately. For reference, I think my tires are rated to 44.
12-01-2010, 02:52 AM
#22 (permalink)
Originally Posted by Arragonis
Rob - why not with a Diesel ?
don't want to fry the starter repeatedly turning over the high compression derv-iness
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
12-01-2010, 04:20 AM
#23 (permalink)
The PRC.
There was a discussion which included the Ford Focus with stop-start a while ago and one feature was an uprated starter. I asked if this was an indication that perhaps a standard one would fry with increased use but the concensus at the time was that it was there to provide a quicker startup rather than to have a longer life.
Interesting...
12-01-2010, 04:57 AM
#24 (permalink)
new starter spooling a light, multivalve 1.6 alloy petrol engine
versus
a 14yr/old starter, heaving over a miss-treated, stubborn, piece of wolfsburg heaviest industrial clag-iron :?
Eo(n)C I can do and it does givce results, but to be honest - I forget to do it! I probably shouldn't admit to this be 90-95% of my commute is on auto pilot unless Costa are doing discount espresso shots at work!
12-03-2010, 04:57 PM
#25 (permalink)
Basjoos Wannabe
versus
I'd prefer not to use the starter myself in your shoes; hence the bump start suggestion.
You'd be suprised that, after training yourself to use coasting opprotunities, how instinctively you'll turn off the engine, know when to restart with a bump of the clutch, know when to start the coastdown for an upcoming turn, etc. Even when off my normal route, I instinctively knock the tranny in neutral when I see a good coasting opprotunity arise.
I know the tendency to go to auto pilot myself. What's scary is when you arrive at your destination, and can't recall the journey!
 RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
12-03-2010, 05:08 PM
#26 (permalink)
Aveo - '08 Chevolet Aveo LS
I drive an automatic aveo... I drive all city. My only mods are ngk ix iridium sparkplugs (ultrafine) (I bought it used with burnt copper), and upper grill block.
EPA for city is 23, I get 28. Its been cold since I started testing it.
12-05-2010, 02:17 PM
#27 (permalink)
The PRC.
@Rob & Shade - Which is more expensive - a starter, a clutch or the fuel used ?
Of course two are only risks...
12-06-2010, 01:31 AM
#28 (permalink)
Pishtaco
That's pretty easy. 100,000 miles @40 mpg = 2500 gal. Assuming gas @$3/gal., the gas costs you $7500. A clutch? Maybe $500. A starter, maybe $100.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
