11-18-2019, 09:35 AM
#51 (permalink)
The Following 2 Users Say Thank You to Daox For This Useful Post:
11-18-2019, 10:10 AM
#52 (permalink)
Nice. Are you compensating for how hot these cells sometimes get?
#53 (permalink)
Perhaps I missed it in the thread, but what are you going to use to connect them? Spot/tap welder and tin strips?
11-18-2019, 12:47 PM
#54 (permalink)
Compensating how? They have a small gap between them for airflow. However, I really don't anticipate them getting that warm. I don't plan to charge them to 100% capacity. Most of the heat generated is in the last bit of charging. Also, the discharge rate isn't that high. The cells will never even see 1C discharge. I am planning on monitoring the heat during charging once the pack is assembled to see if I am way off base.
I'm not totally sold on this yet, but I am thinking thin aluminum strips. We're talking .025 to .040 thick by 1/2" wide. That is plenty to transmit the current we're talking about. It also allows it to be easily deformed to make good contact with the cells.
11-19-2019, 11:47 AM
#55 (permalink)
I printed another set of test plates out. This time the bottom got a deeper recess to hold the cells more vertical. The top plate got a generous chamfer around the cell recess to help guide the cells into the recess. This set of cell plates was 3x3 as I wanted to see how hard it was to align the top plate to the cells. To my delight, it actually worked very well. I stuck the cells in the bottom plate, aligned the top plate and jiggled it a little and it dropped into place.
11-19-2019, 03:28 PM
#56 (permalink)
For maximum benefit do you have a way of measuring the capacity of each cell?
11-20-2019, 10:11 AM
#57 (permalink)
I do have a capacity testing charger. However, I was not planning on testing them. 40 cells would take quite some time to do one at a time. I'll just assume 90% capacity and not discharge them too far. Thats the plan at least. Perhaps I'll capacity test the whole pack once I am done building it.
11-20-2019, 10:28 AM
#58 (permalink)
Depending on your luck you would lose some capacity. Especially if you risk having dead cells.
The Following User Says Thank You to teoman For This Useful Post:
11-20-2019, 10:47 AM
#59 (permalink)
Yeah, having a balanced pack is very important. If these are used cells, I wouldn't be surprised if some of them only had 50% capacity remaining, and that would limit the total capacity of that series string to 50%.
11-20-2019, 03:38 PM
#60 (permalink)
The batteries that I bought were actually brand new and unused. They have been sitting in storage though. However, all the cell voltages are uniform so that is a good start.
The Following User Says Thank You to Daox For This Useful Post:
