Old 02-28-2009, 11:12 PM   #11 (permalink)
Ed Zachary!
Old 02-28-2009, 11:19 PM   #12 (permalink)
Huh?? I'm saying that the curved front end helps aerodynamics
Old 02-28-2009, 11:22 PM   #13 (permalink)
Google "Ed Zachary". Mods might object to my posting the joke here! LOL
Old 02-28-2009, 11:26 PM   #14 (permalink)
I did Google it, which is why I knew you meant "exactly"
Old 03-05-2009, 08:22 PM   #15 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I agree the Brock trailer would be a better performer in reverse.
Pickup guys natter endlessly about towing but when pinned down, they really don't do all that much trailer pulling. 10% opf all vehicle miles would be on the high side.
Car trailers may be the best opportunity for a streamlined trailer. Car guys do travel a lot.
I've been using a design for a trailer to knock the rust off my AUTOCAD skills.
I have two designs I'd like to share. I low-profile "Hi-Lo" toy hauler/travel trailer, and a fixed car hauler/toy hauler/travel trailer.
My problem is I don't think this site can accommodate .dwg files and my camera takes nice pictures but has these huge files.
Can anybody help me?
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 03-05-2009, 09:07 PM   #16 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
If you don't already have it, download the latest version of IrfanView.
Download the latest version of IrfanView PlugIns. (required to read .dwg files)
Use IrfanView to convert your .dwg files to .png.
Should work, but I don't have any .dwg files to confirm.
Old 03-05-2009, 09:56 PM   #17 (permalink)
Download Paint.net and use it to resize your pictures to 800x600 or 1280x960, then save the files and upload
Paint.NET - Free Software for Digital Photo Editing
Old 03-06-2009, 09:31 AM   #18 (permalink)
I see my copy of PaintShop Pro X also opens .dwg files.
If you email me a .dwg file, I'll compare which gives better results - IrfanView or PSP.
If PSP happens to give significantly better results, I'd be happy to convert a few for you.
PS. I suggested .png format for the conversion because it should give better compression (allowing for higher resolution) than .jpg.
Old 03-07-2009, 03:17 PM   #19 (permalink)
backwards
Originally Posted by winkosmosis View Post
If it was going backwards, the air would slam into the door like a brick wall, and fan out. Just because the optimal shape for a given length is a teardrop doesn't mean everything that tapers from front to rear is good. A forward wedge is better than a backward wedge any day of the week.
It's shaped the way it is to fit cars which have a low front. The back has to be big enough to fit whatever fits in the rest of the trailer, because that's where the entrance is.
If it was tapered to the rear, why not just build the whole thing at that height?
Your point is well taken,and given the state-of-the-art for trailer fabrication it's delicious! My "job" is to snipe from the fringe and see if I can rattle the conventional public consciousness.------------------------------------------------ Perhaps before the Sun red-dwarfs,people will load the racecar "backwards" into a teardrop trailer,which closes over the car after it is secured.----------------------------------------------------------- By "killing" the 70% of drag behind the trailer,the racer will make the meet with more money in his or her pocket,more fuel left at the gas station behind them,no super-tankers between the gas station and the Persian Gulf,and clearer air between the bleachers and finish-line.That would be the difference.
Old 03-21-2016, 12:51 PM   #20 (permalink)
…people will load the racecar "backwards" into a teardrop trailer,which closes over the car after it is secured. …By "killing" the 70% of drag behind the trailer,the racer will make the meet with more money in his or her pocket,more fuel left at the gas station behind them,no super-tankers between the gas station and the Persian Gulf,and clearer air between the bleachers and finish-line.That would be the difference.
I realize I'm dredging up an old post, but I only discovered this trailer today, and came straight here to perform a search.
As it pertains to the rounded tail, I wonder what it would take to make a tail section that lifts like the nose of a C5 Galaxy. Could a clever contraption of torsion springs and hydraulic dampers could do the heavy lifting? Perhaps the dead space inside the cone could be used to store Race Ramps or similar product to load vehicles/cargo. Maybe a cargo net, suspended from inside the cone, could be used to secure small items. I think a mildewed, old Airstream could make a likely prototype candidate.
The Following User Says Thank You to Hog Dr For This Useful Post:
aerohead (03-22-2016)
MetroMPG.com: Electric pusher trailer MetroMPG Fossil Fuel Free 30 04-23-2015 04:24 PM
Aerodynamic Heavy-Duty Truck Trailer Cuts Fuel Consumption and Emissions By Up to 15% SVOboy Aerodynamics 11 12-27-2011 08:18 AM
Areomodding my 6x12 enclosed trailer Chris D. Aerodynamics 56 11-16-2008 10:58 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 05:14 PM
Cap vs Trailer: Trailer wins! bennelson Aerodynamics 10 05-08-2008 11:08 AM
