Go Back   EcoModder Forum > AltModding > Saving@Home
Old 09-09-2021, 02:27 PM   #1 (permalink)
Building a stump grinder
I make a lot of stumps. I want to get rid of them quickly with out any other energetic materials besides gasoline.
I was able to get a Honda gx390 11hp motor from the local tractor auction for $200, it's a $700 motor new, for recoil, no-electric start, no magneto.
Figured I can use it on the stump grinder or leaf pusher.
On youtube 5hp stump grinders look tragically slow, so I'm sticking with the 11hp.
Oh and did you know the harbor freight horizontal 22hp v-twin motor is now $900?
(I'll make it upgradeable to the 22hp if I start using the stump grinder to turn stumps into cash, because then time is money)
Old 09-09-2021, 02:41 PM   #2 (permalink)
Why? My preferred method to [fell/fall?] a tree is to dig out the root and cut below ground level, then use the weight of the tree to lever it out of the ground. Then all you need to do is fill the hole.
The best accident is no accident -- Elon Musk
Old 09-09-2021, 03:38 PM   #3 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Why?
I don't know. I'm stumped.
I do know that if you make a tree fall it's called felling a tree.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
Cordonutts (10-03-2022)
Old 09-09-2021, 03:46 PM   #4 (permalink)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 21.74 mpg (US)
also, if you're deaf, does it make a noise?
Old 09-09-2021, 04:21 PM   #5 (permalink)
What about using the ground stumps as a feedstock for a wood gas generator?
Old 09-09-2021, 10:57 PM   #6 (permalink)
Ain't got time for that.
freebeard (09-09-2021)
Old 09-09-2021, 10:57 PM   #7 (permalink)
I might do that but I don't know if separating the wood chips from most of the dirt is feasible.
Old 09-09-2021, 11:24 PM   #8 (permalink)
It's good exercise.
Old 09-10-2021, 09:33 AM   #9 (permalink)
Big stumps dont have a lot of dirt attached, but ones from, say, a 6" diameter have lots of feeder roots at the base. Pinballooking over on ecorenovator has a stump root cutter if you have a backhoe
freebeard (09-10-2021)
Old 09-10-2021, 05:41 PM   #10 (permalink)
Does it need to be as clean as a surgical room anyway?
