04-17-2009, 03:18 PM
#11 (permalink)
EV OR DIESEL
Originally Posted by Big Dave
Better yet. Forget the aero and transplant in a 6.5 diesel. They're almost a bolt-in.
Minimum 25% improvement in MPG.
Are you serious?
Because if you are I may have found a new personal toy.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
04-17-2009, 03:30 PM
#12 (permalink)
Is the diesel an iron block? If so, it would be much heavier and mess up the handling.
04-17-2009, 03:37 PM
#13 (permalink)
EV OR DIESEL
Assuming that we are talking about the LB7/LLY; it's iron block Aluminum cylinder heads.
My understanding is it's similar weight to an iron block small block chevy.
Definitely heavier than the LS1.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
04-17-2009, 10:07 PM
#14 (permalink)
Which type and who has done it?
04-17-2009, 10:13 PM
#15 (permalink)
04-17-2009, 11:27 PM
#16 (permalink)
As I recall a friend of mine who used to run his car at "open track" events said the Z06 (C5) vettes would "pop" (his word) the rear rotors cracking them from exsessive heat. I do understand that its a more extreeme use of the vehicle.. Just something to keep in mind.
04-20-2009, 11:55 AM
#17 (permalink)
Are you trying to make it faster or conserve fuel?
I believe there is a gap in bodywork under the engine. An undertray would benefit you here. If you are aiming for speed you could build a full set of tunnels under it, rules permitting.
As for the vortex generators question, there is a gent on the Airtab website who put them across the back of the deck lid & down the rear quarter panels. He claims in the neighborhood of 2-3 mpg increase. Which if true, should help in both departments.
Don
04-20-2009, 09:28 PM
#18 (permalink)
Don
Both if possible, I saw the airtab thing just wanted to if that was real.
04-20-2009, 10:24 PM
#19 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
Check this site for discussions on airtab and vortex generator use.
04-20-2009, 10:25 PM
#20 (permalink)
Good luck w/ the project, in whatever direction it takes you, and welcome to EM!
