Old 05-30-2014, 07:32 PM   #21 (permalink)
Originally Posted by Insight for life View Post
.30 for the 2001 insight? uh think again people.
I call phooey on the whole thing! Maybe i'll go pick up some 19inch turbine wheels and call it a day.
Back to la la land i go---->
I try to be helpful. I'm not an expert.
Old 05-30-2014, 08:04 PM   #22 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by Thenorm View Post
the quoted 0.23 is for the special bluemotion edition in europe with extra features such a narrow LRR tires, grill shutters, etc.
Correct; Mercedes claims .28 for the CLA250, and .22 for the CLA180 BlueEfficiency. Just goes to show how much Cd can be influenced by the details.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
aerohead (05-31-2014)
Old 05-30-2014, 08:10 PM   #23 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
G1 Insight drivers pretty upset at Car & Driver!
That's interesting, of course. The article speculates on the same theme. But .28 is still lower than the C&D tunnel offers (.30). So, I'm still wondering if the testing method makes its own noise. Did Mercedes test without the wheels spinning? That kinda thing.
Old 05-30-2014, 08:20 PM   #24 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
One SAE Paper from General Motors in the 1960s reported that the difference in Cd between spinning and stationary wheels was of such a low statistical significance that it didn't warrant the time and expense to test; and spinning tire effects could be easily simulated with trip strips in the tire/wheel area.
Exposed-wheel race cars MUST be tested with spinning wheels.
Old 05-30-2014, 09:00 PM   #25 (permalink)
Moderator
Vman455's Avatar
I wonder how Cd is actually calculated in a wind tunnel? Is it derived from total drag force and calculated frontal area? If so, that leaves a lot of room for fudging--er, estimating--numbers.
Old 05-30-2014, 09:49 PM   #26 (permalink)
...beats walking...
Fore/aft force gauges under each wheel measure drag resistance.
Vertical force gauges under each wheel measure LIFT & DOWN forces.
The Following User Says Thank You to gone-ot For This Useful Post:
Old 05-31-2014, 06:52 AM   #27 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Nissan would beg to differ. They test with wheels spining and the engine running to maximise under hood airflow management too.
What was considered adequate by GM in the 60's isn't nessesarily best practise today. It's unlikely we'd have fairly conventional looking 0.22CD sedans with that attitude.
Old 05-31-2014, 02:04 PM   #28 (permalink)
M-B wheels spinning?
Mercedes-Benz uses the FKFS wind tunnel that Kamm built in the late 1930s.It does not have a moving floor,or provision to roll the wheels unless it's been recently modified.
Old 05-31-2014, 02:21 PM   #29 (permalink)
how calculated
From: Drag Force = ( 1/2 X rho X Cd X A X V-squared ),
they measure the actual axial drag force,then using actual station pressure,calculate the air density at test time,then using the projected frontal area,and actual test section air velocity, squared,the coefficient falls out of the equation.
To complicate matters,the EPA does not recognize the frontal area of the side-view mirror(s).
The drag reflects the actual frontal area,including the mirrors.
If the drag is mandated to reflect frontal area sans mirror(s),then the coefficient of aerodynamic drag will be arbitrarily high.
A marketing statistician could 'cook' the numbers.
It's regulated ambiguity.
some_other_dave (06-02-2014)
Old 05-31-2014, 02:29 PM   #30 (permalink)
differ
I'm not certain what Nissan's tunnel specifications are,and how their quanta compare to other facilities.
General Motors research was conducted at Lockheed's Marietta,Georgia facility.It is considered a world-class wind tunnel,good enough for the Skunk Works and all major NASCAR teams.
GM has produced Cd 0.089 vehicles.I'm not sure what Nissan's claim to fame is.
If you have some technical information from NISSAN it would be most appreciated.Hopefully it is not from the same tunnel that their 280-ZX was developed in.
NeilBlanchard (05-31-2014)
