Old 01-14-2009, 08:19 PM   #1 (permalink)
Tracy - '00 vauxhall corsa
check out my taped hub caps!
this was easy to make look nice!
ID:	2579   Click image for larger version
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 01-14-2009, 08:20 PM   #2 (permalink)
duct tape is king. im gonna try it on my tricky textured plastic wheel arches next.
Old 01-14-2009, 10:06 PM   #3 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Pontiac Firefly 3dr
90 day: 40.08 mpg (US)
Duct tape degrades quickly in UV (sun) light. The adhesive dries and becomes powdery.
Old 01-14-2009, 10:27 PM   #4 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
I used foil tape on my alloys and it turned out fine. Been there several weeks without a problem. I have since removed one spoke because it was ripping around the valve stem. And I figure at least now I can say its got plenty of brake cooling blah blah.
With them fully taped up though I saw 0.9 mpg difference average according to some scan gauging.
Old 01-14-2009, 10:41 PM   #5 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
crazier than a cereal bowl on a sube carb!
Old 01-15-2009, 12:44 PM   #6 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
I used packaging tape to attach the coroplast discs to my trim rings, then painted over the discs and tape. Theyre still holding up just fine. I installed them at the beginning of August and drove it till the end of November.
Winter daily driver, parked most days right now
Summer daily driver
Old 01-15-2009, 07:54 PM   #7 (permalink)
maybe some kind of varnish coating would help the tape fight UV
Old 01-16-2009, 02:25 AM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
modmonster -
Hrmmmm. I wonder if there is a more "UV durable" version of duct tape. I like the foil tape idea, but the duct tape is a better color match and I think it's "flexiness" (can't think of a better word) is more compatible for the shape of your wheel cover.
CarloSW2
American Solar Energy Society
Old 01-16-2009, 09:02 AM   #9 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
"Spar" varnish is designed for boats, and has UV inhibitors built in. It still won't save the adhesive from deteriorating, though.
Old 01-17-2009, 10:45 PM   #10 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Counterintuitively, clear duct tape is more durable in UV.
Hybrid home conversion with rear hub motors blueflame Hybrids 42 01-25-2011 03:51 AM
HELP! Check engine light - Loss of power bennelson Off-Topic Tech 28 07-07-2009 06:13 PM
"Pizza pan" hub caps (2008 Civic)? KJSatz Aerodynamics 2 08-05-2008 12:14 AM
Pruis Pizza Pan Hub Caps.... justpassntime Aerodynamics 1 07-14-2008 09:55 AM
Solid wheel caps (moon discs - where to get?) NoCO2 Aerodynamics 48 02-12-2008 05:23 PM
