Old 11-05-2013, 11:03 AM   #31 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by bobo333 View Post
i havnt got an SG or MPGuino yet but if i do get them how can i hook them up so that they read right when i flick the killswitch?
Don't know about the SG, but the current MPGuino code will correctly handle this. That was one of many improvements made to the code.
The Following User Says Thank You to t vago For This Useful Post:
bobo333 (11-05-2013)
Old 11-06-2013, 12:43 PM   #32 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
K, I did the common power injection kill. Works reasonably well (small switch on the shifter and an automotive relay connected to 4+4 spades).
It does make the check engine light come on till the next power cycle, but it is a 94 so I don't care. I guess fooling the ECU without rebooting it completely is the other option, this will do for now
Old 01-26-2015, 08:54 PM   #33 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
fuel injector wire
Originally Posted by brucepick View Post
Found the inj. power wire.
It's in the connector in photo but not the fat yellow + black wire noted earlier.
It's yellow + black, the top position, center column (as shown in photo with connector clipped to bracket).
Nice.
What method did you use for the splices, and how is it working for you?
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
95 Civic EX - Too much power abshnasko EcoModding Central 16 03-01-2011 11:19 AM
Diesel Power Magazine Disappointment. ConnClark EcoModding Central 16 06-05-2009 10:39 PM
Removed '00 Civic power steering belt and got good results but... hondaworkshop EcoModding Central 8 10-07-2008 01:23 PM
