Old 06-22-2023, 05:19 PM   #991 (permalink)
Originally Posted by myself at #725
The ancient Greeks thought Universe is a dodecahedron, that wraps around to opposing faces like a side-scrolling 8-bit video game. Being a fan of the Platonic solids (and the Archimedian semi-regulars) it sounds as good as anything to me.
Found this today, via Hacker News
Didicosm
Loops Across Space
Adidicosm is a certain kind of three-dimensional space, one of ten platycosms, the name given by the mathematician John Conway[1] to a space that has a finite volume, no boundary, and a flat geometry: the same geometry locally as ordinary Euclidean space. Four of the ten platycosms are non-orientable (a property for which the Möbius strip is the most famous two-dimensional example) which would lead to serious complications if we lived inside such a space, as it would allow matter to be transformed into its own mirror image just by travelling around a loop. The remaining six, including the didicosm, are potentially candidates for the shape of our own universe, if it happens to be finite.[2] (The didicosm is also referred to as a Hantzsche-Wendt Manifold, named after the mathematicians who discovered it in the 1930s, but we will use the name that Conway gave it much later.)
A didicosm can be formed by taking a rectangular prism, as in the image on the right, and “identifying” its faces, so that when you move within the prism to any point on its boundary, you re-enter it at a different point, determined by the way the faces are matched up with each other.
All this is through the frame of Cartesian Coordinates. They get close to Sytnergetics at the end, finding triangulations inside the cube with integer values.
The image on the right shows one solution found from a triangulation of the didicosm. Here, the blue line represents the loop X4, while the triangles have been coloured to show various integer coefficients: yellow=1, orange=2, magenta=3, red=4.
Old 08-06-2023, 10:13 AM   #992 (permalink)
MSU physicist debunk once and for all the stupid belief the "suns irradiance only changes by 4%" with ground based observation....
Old 08-06-2023, 01:01 PM   #993 (permalink)
Is this the story of which you speak?
msutoday.msu.edu: Spartans help make a surprising discovery about the sun
Old 08-07-2023, 01:23 PM   #994 (permalink)
www.mdpi.com: Comparison of Recently Proposed Causes of Climate Change
This paper compares the ideas contained in the main papers published on climate change since World War II to arrive at a suggested consensus of our present knowledge regarding climatic changes and their causes. Atmospheric carbon dioxide is only suggested as a cause in one theory, which, despite its wide acceptance by Politicians, the media, and the Public, ignores the findings in other studies, including the ideas found in the Milankovitch Cycles. It also does not explain the well-known NASA map of the changes between the global 1951–1978 and the 2010–2019 mean annual temperatures. The other theories by Oceanographers, Earth scientists, and Geographers fit together to indicate that the variations in climate are the result of differential solar heating of the Earth, resulting in a series of processes redistributing the heat to produce a more uniform range of climates around the surface of the Earth. Key factors are the shape of the Earth and the Milankovitch Cycles, the distribution of land and water bodies, the differences between heating land and water, ocean currents and gateways, air masses, and hurricanes. Low atmospheric carbon dioxide levels during cold events could result in too little of this gas to support photosynthesis in plants, resulting in the extermination of most life on Earth as we know it. The 23 ka Milankovitch cycle has begun to reduce the winter insolation received at the surface of the atmosphere in the mid-latitudes of the Northern Hemisphere starting in 2020. This results in extreme weather as the winter insolation reaching the surface of the atmosphere in the higher latitudes of the Northern Hemisphere decreases while the summer air temperatures increase. It heralds the start of the next glaciation.
According to this, the inflection point was in 2020. I just bought an insulated aircrewmen overall, it will pair well with the E. German sniper suit mummy bag (you can walk around in) and insulated boots. Next I will look for a union suit with sliver threads woven in so I can wear it all for months at a time.
Old 08-07-2023, 01:49 PM   #995 (permalink)
Need a NODAK missleman bunny suit for them -40f days as long as you don't mind international orange or olive drab.
Old 08-22-2023, 03:54 PM   #996 (permalink)
What if it's not just a story or a nightmare but someone trying to describe what they saw?
Say a gargantuan solar explosion that blew away 12 chunks of solar material from the surface of the sun.
And the moon happens to be visible at the time.
Old 08-22-2023, 05:19 PM   #997 (permalink)
http://www.thunderbolts.info/wp/2015...-sky-series-2/
This series, Discourses on an Alien Sky, begins an extended exploration of ancient cultural themes introduced in the documentary, Symbols of an Alien Sky. The subject is the ancient experience of towering celestial forms that are no longer present. From a single snapshot of the configuration, we can work backward to the first appearance of these bodies out of an undifferentiated cloud or sea of dusty plasma. We can then follow the configuration’s evolution through phases that range from quasi-stability to earth-shaking catastrophe. The foundation of this reconstruction is provided by the points of agreement between ancient cultures the world over.
oil pan 4 (08-23-2023)
Old 08-24-2023, 01:14 PM   #998 (permalink)
Oumuamua is likely a technological object.
https://youtu.be/5lzMzq8LR24?si=rxDdE-oet6MQJPJH
Old 08-24-2023, 01:29 PM   #999 (permalink)
It was hailing balls of fire in Hawaii, like some biblical end of days stuff.
https://youtu.be/5Z0beYjT6ko?si=GnJ_V3NB37ulZBxR
Old 09-02-2023, 08:58 PM   #1000 (permalink)
For freebeard: another Atlantis style cataclysmic event consuming land between London and Denmark. Caused by some rock shelves falling off Norway?
Saw it on PBS EONS.
Narrator actually said like all the Atlantis style floods. Apparently there are histories on most major continents.
