Old 02-14-2010, 11:23 PM   #31 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
I have already replaced the turn signal and tail light bulbs with led's. I don't know what you mean by fender eliminators. please discribe?
Old 02-15-2010, 02:12 PM   #32 (permalink)
Supra - '88 Toyota Supra
superhawk - '98 Honda superhawk
Last 3: 27.62 mpg (US)
Lesabre - '96 buick lesabre
3800
90 day: 25.85 mpg (US)
Saturn - '97 Saturn Sc2
Team Saturn
Sports Cars
90 day: 39.12 mpg (US)
Truk - '99 Ford F150
Team Ford
Pickups
90 day: 24.43 mpg (US)
Golf - '03 Vw Golf
90 day: 38.57 mpg (US)
i could'nt find one for your bike but this should give you an idea of what i am talking about if you want to make one
Jardine Supersport Rear Fender Kit - GSXR600/750 (08 and newer)
Old 02-17-2010, 10:09 PM   #33 (permalink)
Motorcycle
Motorcycle
Janvos39 I did a quick test out in the garage to see what path my foot and leg could / would make when steping up onto the foot peg to mount the bike, and discovered that my foot goes over the seat where the rider sits without having to be a contortionist. This will allow me to fill up the space behind my back and be able to do as you suggest and reduce drag with a fairly large tapered section behind the rider. thanks for the insperation to look harder at the issue. What I have in mind is a ferm tapered nylon seat bag directly behind the rider as lugage bag.
Old 02-18-2010, 11:19 AM   #34 (permalink)
3800
Team Saturn
Sports Cars
Team Ford
Pickups
Golf - '03 Vw Golf
a fender elimenator is a little bracket that holds the turn signals and license plate so you don't have that big fander hanging down.
Old 02-25-2010, 12:13 AM   #35 (permalink)
Motorcycle
Motorcycle
If I ask the question what can be done to a motorcycle that does not involve fabrication, that would reduce fuel consumption? I come up with install a large tank bag, to fill up the space between the fairing wind shield and the rider, and install long smooth sadle bags that fit close behind the riders legs. What these two things do is reduce the rate of change of cross section which should reduce air drag. an othe easy change is to go up one tooth on the front sprocket to reduce rpm.
what other answers to the above question can you think of?
Old 02-25-2010, 12:21 AM   #36 (permalink)
Any studies on tank bags? Me thinks they're completely in a turbulent wake and would have no aero effect.
Old 02-25-2010, 01:03 PM   #37 (permalink)
Motorcycle
Motorcycle
I know of no study on aero effects of tank bags, you are corect in thinking that they are in a tubulent wake. That is why filling up that area would have a similar effect to a "boat tail"
Old 02-25-2010, 04:33 PM   #38 (permalink)
Well, yes but mostly no.
Old 02-26-2010, 04:41 PM   #39 (permalink)
Motorcycle
Motorcycle
To gain a better understanding as to why/how a tank bag would/could have an aero effect look at all the posts related to pick up truck box covers and canopies. The other example you might want to consider is the aerodynamics of a convertable with the top up and with the top down. I think we can agree that a convertable has lower drag with the top up. The motorcycle examples can be found on C. Vetter web site; he goes to cosiderable trouble to close in all openings as does janvos39 with his burgman scooter. Basic fluid dynamics also tells us that changes in cross section absorbe energy so that anything one does to eliminate unnessisary changes in cross section will help reduce drag. the tank bag will reduce the unnessisary change in cross section behind the fairing and between the rider and the fairing. An other example is the effort put into filling the in the space between the truck and the trailer on highway tracktor trailer units.
Old 02-26-2010, 07:23 PM   #40 (permalink)
It won't because it the air is completely turbulent behind the fairing and windshield and tank bags do nothing to effectively close openings or smooth out changes in x section.
Now, maybe if you make one out of clear PVC and have it rest on your legs and extend out to the sides far enough to interact with the airstream, and extend upward in front of your face to interact with the airstream, you might have something.
Potential engine mod? Otto to Atkinson conversion AndrewJ EcoModding Central 88 10-24-2022 04:53 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 02:17 PM
What are your 2008 mod goals / wish list? MetroMPG EcoModding Central 45 01-02-2009 02:57 AM
Getting more efficiency out of a ZX2. Small list of mods and driving tips for it. koihoshi EcoModding Central 9 07-20-2008 05:26 AM
