Old 04-16-2014, 04:16 PM   #1 (permalink)
2003 Civic Hybrid EOC Kill Switch/Injector Cutoff simple how to
I looked all over for a diy of how to do a kill switch for a civic hybrid and couldn't find much. I finally found a wire diagram of the injector relays.
The Yellow/ Black wire is the ground for the injector relay number 1 which is a brown relay on my car, that is the one I installed a switched off.
Materials list:
Momentary switch normally closed
Wire (14 gauge)
Wire connectors
Misc ties-tapes
How to:
Locate the relay bank which is behind the glove box
remove the kick panel under the glove box
Lower the relay bank by pushing the lever and lifting the bank up and out
Cut the yellow/black wire
Splice in the wire for the switch
Run the wire to the gear shift or where ever you want to mount it
And enjoy.
Only my second DIY Tread so don't hate.
Any positive input is greatly appreciated
Pictures speak a thousand words see below
ID:	14889   Click image for larger version
ID:	14890   Click image for larger version
ID:	14891   Click image for larger version
ID:	14892   Click image for larger version
Old 04-16-2014, 05:33 PM   #2 (permalink)
Is the switch on the one yellow/black stripe wire? From the photo it almost looks like the red wire was spaded.
Old 04-16-2014, 06:19 PM   #3 (permalink)
Yes,
I made sure it is the Yellow and Black wire. I'll see if I can get a better closeup of the pic. So many wires right next to each other.
Edit: Pic about the closest I can get with cell phone camera.
Old 04-16-2014, 09:44 PM   #4 (permalink)
Thanks bro. Ill have to check my book on my insight. I want to say each injector wire grounds back to its own pin on the ecu vs being clumped together to the relay like yours. Be nice to FAS the car as autostop is flaky. Then add another switch to the ignition start lead. Maybe a centered switch with a circuit on either side to either start or FAS?
Old 04-17-2014, 02:14 PM   #5 (permalink)
darcane's Avatar
In this thread, we figured out basically the same thing. While yours is a hybrid, I think this part of the wiring is the same with our conventional Civics. I was concerned with cutting that particular wire because I wasn't sure if it would kill the immobilizer circuit also.
Any trouble with it when you kill the engine? Do you need to key off/key on in order to restart?
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 04-17-2014, 05:40 PM   #6 (permalink)
Its only been one day but It seems to be working great. I DO NOT have to key off to restart. I can either bump start the engine or just turn the key to start if I'm not rolling. I don't know if I have the immobilizer system or not.
I do have a bad IMA battery, been bad since I bought the car so both my Check engine light and IMA light are on so I don't know if this mod will cause a CEL.
The Following 2 Users Say Thank You to Mrtony5 For This Useful Post:
darcane (04-18-2014), elhigh (05-08-2014)
Old 04-18-2014, 12:53 PM   #7 (permalink)
I couldn't find that thread when I was searching before thanks for posting that here.
I read through it and what are the benefits of using a relay for the switch ?
Old 04-18-2014, 01:21 PM   #8 (permalink)
darcane's Avatar
The way I have it wired up, if my switch fails or the wiring gets damaged, the car will still run.
The amps are low enough that amperage isn't really a concern here.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 04-22-2014, 04:01 PM   #9 (permalink)
Ahh I see.
I just ordered a relay to modify the wiring just in case the switch fails.
I will update the wiring process once I get it done.
Old 04-24-2014, 01:22 PM   #10 (permalink)
TBA - '07 Honda Fit
DELETED
