07-04-2009, 11:22 AM
#131 (permalink)
PaulH
Here's a code sample of what I mean, where pwmDuty is in the range 0-16352. You want it so that it scales to 0-511, not 0-512 (so don't use 0-16383, which is 2^14 - 1). You don't even have to have a separate pwmDuty variable that actually is in the range 0-511. Just change pwmDuty at the end. Let's say you want the current to stay constant at "targetCurrent":
ReadCurrent();
if (current < targetCurrent) {
pwmDuty++;
if (pwmDuty > MAX_PWM_DUTY) {
pwmDuty = MAX_PWM_DUTY;
else if (current > targetCurrent) {
pwmDuty--;
if (pwmDuty < 0) {
pwmDuty = 0;
if ((pwmDuty & 31) >= 16) { // round up!
OCR1A = (pwmDuty >> 5) + 1;
else {
OCR1A = pwmDuty >> 5;
07-05-2009, 05:45 PM
#132 (permalink)
Joe
nice! i tried the 'finePWM' thing and it works great! I have a pot thats read into the ADC to set the desired current and the program changes the duty cycle until the current reading matches it (after a little scaling).
I did a proportional method that's overdamped - the current just ramps up to the desired current and levels off without any overshoot. I even moved my alligator clips around so that the load resistance reduced to about 1 ohm and the current control was still stable. That should be about right for my pack of 72 cells, but i bet a pack of AGMs would be less. I have a 12V AGM i can test it on - i'm just a little nervous about testing on a battery for whatever reason...
anyway, i could control the current up to 20A and down to 1.5A with the pot. I think my opto-isolation circuitry messes with the low duty cycle output which shouldn't be a problem with a battery (needs a higher dutycycle to overcome the battery's voltage).
here's the part of the control code...
USERcurrent is the setting from the pot, outputcurrent is from the current sensor, and PWMfine is a 16bit variable.
Code:
currenterror=USERcurrent-outputcurrent;
deltaPWM = currenterror/2;
PWMfine=PWMfine+deltaPWM;
OCR1A=PWMfine/128;
07-05-2009, 09:42 PM
#133 (permalink)
PaulH
Joe! You and your fancy P loop! hehe. Awesome job! I think you might be right about agms. Very low internal resistance. I can't wait to see if you blow something up! This is so exciting! A charger that can go up to 20 amps isn't cheap. Manzanita 20amp chargers are like $2000 I think. So, if you can keep the DIY parts price below, say... $1500, I would say you are doing a huge service to the EV community! I have a bunch of 220uF 450v ripple caps and high voltage mosfets and igbts that someone sent me, and I want to make a charger like your fancy one! ya!
07-17-2009, 01:56 AM
#134 (permalink)
Joe
So. It's been tough splitting my time between this project and installing the new controller from Paul. Pretty much, I work on the car in the evening while it's still light and not so f-in hot, then go in and play around with the charger.
I finally worked up the guts to hook it up to a battery, so I grabbed the 12v atm out of my ecar (it's all torn apart anyway while I install the controller) and connected the alligator clips. I did a couple tests at low current to see how the current sensor was working. Even down below an amp, the output was filtered enough by the cap I have on the adc input to be constant. Then, enabled the control loop in the code and let her rip! No problems. The control loop held the current constant without a hitch. I only went up to 8 amps since I knew the battery was already fairly charged.
Next step is voltage measurement and programing it all into some sort of charge algorithm.
07-17-2009, 02:03 AM
#135 (permalink)
PaulH
This is awesome!!! I was really wondering how different it would be on a real battery. Oh ya!!! I'm excited about the charging algorithm. I need to make one of these buggers! Awesome Job!!!!!
YOU CAN'T TEACH THAT, IT'S INSTINCT!!!
EDIT: You took an ATM out of your car? Did you take it from a bank? Can I have some of the money?
07-17-2009, 11:33 AM
#136 (permalink)
Joe
i did! it's awesome! my car is a spontaneous ATM generator, so ya i'll send some your way!
oops, i meant agm...
07-22-2009, 02:35 PM
#137 (permalink)
anyone knows the updated total price to build this or purchase this fully assembled?
EV59rag
Parting out my EV.
ES-31C D&D Motor
Alltrax 7245 Controller
Paul & Sabrina's Controller (never used)
07-22-2009, 07:07 PM
#138 (permalink)
I'm really interested in building my own charger. This thread rocks!!! I was thinking that it might be almost as simple to use a buck/boost regulator instead of a voltage doubler and then a buck and then the pack voltage capability would be pretty much anything people could want (I'm shooting for a 360V nominal pack in my car). Am I missing something that would make this technically infeasible assuming a PIC is used to control the PWM and the charger algorithm? This is pretty much what I'm thinking of:
07-23-2009, 03:40 PM
#139 (permalink)
Joe
Unfortunately, I've been adding things to the circuit without really keeping track. The biggest chunk of the cost is probably the power components. Of course, all the little things add up quick - I think I had an estimate of 300-400 for everything so far. Depends on how crazy you want to get with a box and switches and everything. It'd be nice to add an LED display or something, but that adds more cost. I think if we're under 500 for something very functional, it's a winner. I think I also mentioned that lower voltage/lower amperage would be easier and cheaper to do.
At some point, when this design gets to a full prototype, it'll be easier to put together a bill of materials. as of now, all i have are estimates.
07-23-2009, 03:48 PM
#140 (permalink)
Joe
nope! So what I have so far is just a buck stage, but adding a boost stage would allow for higher voltages. My test on a 12V battery was from 120VAC, while I'd have to run off of 240AC to charge my 144V pack. A boost stage would eliminate that.
Actually, instead of a simple boost stage, what I really want to do is add a PFC stage. It'll act a boost stage and boost any input voltage from 120 to 240AC to ~400VDC, but do so such that there is close to unity power factor. So it'll act as a boost stage, allow the user to plug into any outlet without having to flip a switch or something (maybe lower the power), and could charge higher voltage packs.
I think it'll be easy to add that later (famous last words) after the buck stage and charging algorithms are figured out.
