Old 05-01-2008, 08:32 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
DIY - Basic Fabrication
I have very quickly learned on this site that you guys like me, love to make stuff for your cars. Well as an experienced fabricator, I have a couple of suggestions that should get you through some of your easy projects.
The easiest way to modify an existing part is;
-Cover it with painters tape (The blue one), that way you preserve the original surface.
-Once you have the shape you desire (IE, covered holes smoothed gaps with the tape), you are ready to work with cotton fleece.
-Fleece is relatively inexpensive, stretches well and bonds beautifully with Fiberglass and resin.
-Stretch the fleece over the area you want to mold and secure any way you can.
-Then add your fiberglass, either sheet or floss and mix with resin. The resin you can mix many ways, the hotter you mix it the quicker it dries but the reaction is literally warmer, so be aware of the surfaces you are working with.
-Once dry the painters tape will act as a mold release and you can pull your pieces apart.
This is a very oversimplified DIY, but working with fleece and fiberglass is not hard and will accomplish alot of the DIY projects I see on the site. If I had the time I would offer to help you manufacture stuff, but right now there is just no way. If you need specific advice please send me a tell, I have connections with manufacturers who have 5 axis machinery and can duplicate anything they can scan or get into a computer.
Happy modding ....
PS here are a couple of pieces I made with wooden frames and some fleece, these are part of my trailer queen BTW ...
ID:	649   Click image for larger version
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
The Following User Says Thank You to trikkonceptz For This Useful Post:
Imatech (07-10-2010)
Old 05-01-2008, 09:20 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Sweet post, ...I need to get better at fabrication.
Old 05-02-2008, 12:38 AM   #3 (permalink)
90 day: 51.82 mpg (US)
That was done with FLEECE?
Old 05-02-2008, 08:43 AM   #4 (permalink)
Not just fleece. I'd imagine theres a bit of bodyfiller in there too.
Old 05-02-2008, 08:51 AM   #5 (permalink)
Not as much as you might think. When stretched properly the fleece gave me the shape you see in the pics. Body filler was used to smooth the bumps that the fleece and fiberglass left behind. There is less than a 1/8" of filler on those parts. There is an insane amount of man hours in that interior though ...
SO I encourage you to experiment, it isn't that difficult and with a bit of patience you can accomplish anything.
Laterz ..
Old 05-02-2008, 05:00 PM   #6 (permalink)
Blue - '77 Chevy P/U
Hmmmmmmmmmm i have sheets of fleece around,,,,,,,,,,,,,think the other half will be pizzed
Old 05-02-2008, 05:18 PM   #7 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
VERY nice work.
My problem: I'm stuck with some black ABS plastic to make a grille block.
Challenge #1: getting the correct arcs in the corners of the grille
Challenge #2: cutting the plastic without getting that rough "thready" edge. If I sand it, the edges become dull and the material is shiny. Prep and paint?
Maybe I need to move to a different material.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 05-02-2008, 05:37 PM   #8 (permalink)
it should paint EZ
Old 05-02-2008, 08:01 PM   #9 (permalink)
Originally Posted by RH77 View Post
VERY nice work.
RH77
Well your first problem is easy, just make templates first to make exact shapes, use cardboard, construction paper,anything thicker than paper and form the template. Then trace it on the ABS and cut away.
Then I would paint the whole thing flat black, since with the sun, the unprotected plastic will dull anyhow. I wouldnt stress the looks to much since its for $$ savings and not a show car ...
Then get a bumper sticker that says .... "Don't like the way it looks? Donate now and support the cause" With a paypal address under it ... LOL
Old 05-02-2008, 11:10 PM   #10 (permalink)
Agreed, very nice work Trik.
DIY - Water Injection Stormin' Norman DIY / How-to 46 12-28-2012 12:48 PM
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
Truck Aero, Bed cover DIY tonneau? Chris D. Aerodynamics 84 11-04-2010 11:56 PM
DIY - Black Trim Painting SVOboy DIY / How-to 14 12-15-2008 10:46 PM
DIY - Learn how to Weld...Basic Steps and Equipment Needed XFi DIY / How-to 18 11-11-2008 12:44 PM
