Some more work done on the project today.
I painted the rack black and bolted it in.
The generator was bolted down to the rack.
The bolts and rack also act as the ground for the generator. I thought I might need to add an additional cable as a ground. I haven't done that yet, the electric start circuit worked great without it, but it might not be a bad idea to add a short ground cable to the car frame anyways.
The the electric start on the generator, I made a new power cable - 6 ga - to run from the car's 12V accessory battery back to the generator.
(I wasn't sure exactly which size cable to use for the battery cable. I found some 6 ga. When I checked later, I realized that on the generator itself, it is a 6 ga cable that goes from the solenoid to the starter.)
I stopped at the hardware store and got the right lugs for it. I even had heat shrink and color-coded electrical tape! I know, getting fancy, right?
The only thing I didn't have was a crimper for that size. The "smack it with a hammer" method seemed to make a nice solid connection though.
So now the generator with start with the car battery, but more importantly, will CHARGE the battery when the genny is running.
If only there was some way to remotely start the generator while I am already driving the car...
Oh wait, there is!
On the generator is a multi-pin connector for a remote control panel.
Before going to Electronics Night last night. I e-mailed one of my friends the description and this photo of the connector, to see if he could find me the mate to it. He did, so I can now make my own adapter. The certain pin needs to get grounded to turn on the starter.
If only a car had some way to to activate an electric starter...
Hmmm. Well, I wasn't using the "crank" position on my car's ignition (ever since I took the engine out) so I thought why not reuse that?
I took off the lower dashboard to get to the ignition wiring.
I followed the repair manual to find the wire that should run to the key start position. When I found it, I cut away just enough insulation on it to poke it with my multimeter probe. I clipped on some jumpers and tested it with my meter, by turning the key to start.
Sure enough, the meter jumped from 0 to 12V!
Unfortunately, the generator needs a GROUND connection, NOT 12V power to kick on the starter. So, I added a splice connector to the START wire, and ran that to a 12V relay. When the relay kicks on, it connects the remote start pin to the car chassis.
Now, when I put in the key, I have three choices.
- Off (self-expanatory)
- E.V. system on (I can drive the car as electric)
- Start Generator (does not deactivate EV system)
It feels kinda weird to use the starter in an electric car! Also, it's odd to hear engine noise coming from the REAR of a Metro!
