I got to work on the project for a few more hours today.
My buddy Steve stopped over to give me a hand. We zip-tied up the 12V+ ignition cable under the car.
Most of what we were doing was trying to figure what goes where, and how to fit it all in there.
We decided on
Propane tank on far left.
Circuit breaker, outlet, and starter relay right behind it.
Generator in the middle, with exhaust below.
Demand regulator on the right.
Charger on the right, behind and above the regulator.
Everything fits in the cargo compartment this way.
I cut some plywood to fit inside the bedframe generator rack. It's sized to fit inside the frame, and has a couple of self-tapping screws through the wood, into the frame.
I already had the breaker box and outlet on a piece of plywood, so we just mounted that vertically, leaving enough room for the propane tank. The starter relay and ground screw was also mounted just below the breaker box.
Here's a reverse angle photo:
![](http://gallery.me.com/benhdvideoguy/102724/DSC_7250/web.jpg?ver=12927314360001)
Since the outlet faces the front, it makes it easy for me to put in a Kill-a-watt right there for testing purposes.
As for the charger, it's NOT working right now. I plug it in, it powers, it just doesn't charge. It acts exactly as though the pack is fully charged.
I just got an email back from somebody else who has the same charger. I asked him to open his up to check on that resistor. Turns out I put one of the wrong value in. The value is off by about 25%. I wonder if I can trick it by simply adding an intentionally wrong "programming resistor" where you set the system voltage in the charger. Hmmm... That might actually work....
Also, I had a fun experience getting gas this morning (for my pickup truck for a long trip.) This sign was at the pump.
Oh well, just one more reason to go gas-free!
![Thumbs up](/forum/images/smilies/grinning-smiley-003.gif)
