Old 01-22-2008, 04:07 PM   #1 (permalink)
Fastening wheel skirts
I've been thinking about how I would fasten wheel skirts on the car should I decide to make some. I've read a few DIYs and none I have seen seem like a great option. Ideally you'd want a tooless design that doesn't take long to remove. This obviously isn't the easiest thing for us DIYers. Here are a few things I was looking into. I'd like to hear from others.
Use locating pins on the top of the skirt. Then use a sort of stud on the chassis and a wing nut on the bottom to hold it on. Here is a rough idea.
Use multiple push-to-close latches. Possibly in conjunction with some locating pins on top. This would necessitate a rigid frame for the skirt.
I guess I'm curious how the OEM sideskirts are held to cars? Some sort of plastic snap would probably work great, but I haven't found any good ones readily avaliable.
Old 01-22-2008, 04:25 PM   #2 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
I've been thinking about how I would do this for my own ride, and the idea of several rare-earth magnets embedded in the edge of the skirt struck me. If you have sound steel around the edge of the wheelwell, you could maybe just get the skirt to stay put of its own accord, and yet be easily removable as necessary for maintenance and tire changes.
Old 01-22-2008, 05:55 PM   #3 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
I've seen someone on GS use Dzus (quarter turn) fasteners like these:
I intended to use them on my car, but I couldn't get them locally, and I didn't want to order them online without seeing them first.
While the tool-less thing sounds like a great idea when you're in the planning stages, it's not that big of a deal when they're on the car. I just bought an extra hex key of the correct size, threw it in the glove box and forgot about it.
Plus, with some kind of tool required, it's that much harder for someone to mess with it.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 01-22-2008, 09:11 PM   #4 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I like the idea of the magnets because it would look really clean AND be tool-less.
Since it isn't obvious what's holding the wheel skirts on, nobody is real likely to mess with them.
You may just need to take them off before going through a carwash!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 01-22-2008, 09:20 PM   #5 (permalink)
I've had skirts on my car, and were I to do it again they would either have to be hinged or come off very easily, so that gymnastics aren't required at filling stations to check/add air to the rear tires.
Old 01-23-2008, 08:05 AM   #6 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
I would just put pins sticking out where your wing nuts are and make U groves in the studs so the skirt will slide up in position. Now all I would need is a way to lock it at the top. I would probably use somekind of hook lock like the ones used on rooftop boxes.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 01-23-2008, 11:24 AM   #7 (permalink)
90 day: 51.82 mpg (US)
I just roll the car back a little bit until the valve is at the bottom of the tire. No gymnastics required!
I've gone from duct tape, to velcro to duct tape.
Here's what I'm going to do when the weather warms up again:
My goal is to attach things without need for drilling the sheet metal anywhere (rust concerns - even with undercoating).
The bracket squeezes the lip on the wheel arch and is held in place by the nut, bolt & washer (drilled only through the bracket).
The fastener can be a screw, but I'm considering the plastic automotive fasteners with the center button that releases its grip when pushed in - no tools required.
Old 01-23-2008, 11:36 AM   #8 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Metro's method is really a good idea in that there's no permanent damage... In fact, I was ready to implement a similar method of attaching skirts... But I discovered my car doesn't have that flange :/
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 01-23-2008, 12:15 PM   #9 (permalink)
These came to mind as I was thinking of this too. However, I don't know where you could buy them? Also, how would you fasten the top of the skirt with these?
Old 01-23-2008, 12:18 PM   #10 (permalink)
MechE
Local auto parts supply should have replacements They might be called trim fasteners. Otherwise, I imagine every stealership will have them on hand...
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Done: A-B-A test on rear wheel skirts - Corolla, Camry Hybrid MetroMPG Aerodynamics 11 06-06-2009 03:49 PM
Geo Metro rear wheel skirts - 2 examples MetroMPG Aerodynamics 10 02-27-2008 10:09 PM
Found a coastdown hill! Mini comparo: windows vs skirts vs hatchback MetroMPG Aerodynamics 4 11-27-2007 11:40 PM
