01-27-2019, 06:37 PM
#231 (permalink)
You deleted the front sway bar, right? Consider that most FWD cars come with a front sway bar and usually are tuned for understeer, and it makes sense that you’re experiencing oversteer in snow, especially when you also consider that you removed lots of weight from the rear of the car (still living with the hatch delete?)...
I would give some serious thought to putting the front sway bar back on and relocating the battery to the rear...
My current Ecotec project...
My last Ecotec project...
01-27-2019, 06:38 PM
#232 (permalink)
Master Ecomadman
I use to think the skinniest tires were best in snow, so I put 165/80R15 tires on my 87 4wd Subaru. Well they were not really snow tires, and so what would happen in the snow, is the tires would pack the snow down, then slide off the sideways off the mound. Fatter tires wouldn't slide off sideways.
You need another 500 lbs in the car.
Sway bar has nothing to to with it.
- Tony
02-06-2019, 03:00 PM
#233 (permalink)
I'm happy to say I'm not the only person with this issue: I was recently behind an old Ford Ranger who I noticed was constantly correcting oversteer through a gentle, sweeping highway curve in slippy conditions at ~65 km/h (40 mph)
Have you put it on a scale to get the front/rear axle weights?
Nope never have done this.
Good memory!! Good theory! Yes both F/R bars are off the car.
HOWEVER, you would need weight transfer for this theory to work, and I swear there was so little traction when this happened, there would have been no suspension compression to speak of for the bar(s) to work against.
I'm talking about driving through the gentlest of curves at a moderate speed with hardly any steering input.
So far I've put all the interior bits/hardware back into the rear of the car. (Partly also because it's noisy driving on wet roads, and the roads are mostly wet this time of year.) I also have a bit of extra weight I can add to the cargo area. But I haven't yet had a chance to drive it on slippery roads since doing this.
Will keep you posted.
02-06-2019, 11:22 PM
#234 (permalink)
Master procastinator
How about your tires age? I ruined our winter tires by storing them outside not too well shaded and supposedly "dried" them in the sun. Lousy traction this winter.
Also: what kind of tires are they?
02-07-2019, 09:40 AM
#235 (permalink)
These are the tires on it:
Lots of meat, not sure what age they are, but at least 5 years. Probably more. The treads themselves are still easily squishable by hand. They're not hard as hockey pucks. I store them in bags in the shed in the summer.
That said, I have driven the Firefly with ancient and terribly slippery "all-season" tires in the snow, and it was definitely not as tail-happy as this Metro. I'm still holding on to the idea the difference is the weight in the rear. I would confirm today, but that would require me to scrape a layer of ice off the windows from freezing rain.
02-07-2019, 04:11 PM
#236 (permalink)
weight seems to have worked
I checked the date on the snow tires: just under 5 years old.
And I had it out this afternoon. MAN! It's like a fat old luxury car - so quiet with the interior back in. What a treat! And it rides noticeably smoother with the stock weight in it, plus a few extra lbs in the cargo area. Cadillac, baby!
And the handling seems much more stable. I didn't get to test highway speeds, but on a snow-covered road at ~65 km/h = 40 mph, I had to flick the steering to get the back end wagging, whereas before I had to actively steer it to keep it in line.
Next slippy highway trip will confirm, but I think that was it.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
02-11-2019, 10:16 PM
#237 (permalink)
222222 kms
So on the current tank of gas, I will have put 10,000 km (~6200 mi.) on the winter beater Metro. That's in just over 2 years, and mostly winter duty.
I was going to say I have a love/hate relationship with this wee beastie, but maybe it's more like a "tolerate/hate" relationship.
02-25-2019, 03:51 PM
#238 (permalink)
10,000 km Review
The Metro just passed 10k km (~6k miles) in my care.
I got it in July, 2016, so that works out just 4000 km a year on average.
It's a like/hate relationship:
1) Like: Lifetime Fuel Economy: 59 mpg (US), 4 L/100 km, 70.9 mpg
Considering most of my driving is in cold weather/winter conditions, I'm OK with that.
2) Hate: crap clutch
Despite having been replaced by the previous owner just 30k km ago, the clutch in this car is garbage. I'm pretty sure it's got broken damping springs in the disc. The weird thing is the problems come and go. I've complained about it before: Update: self-healing clutch. I don't hate it enough to fix it, though!
3) Like: hmmm...
Having trouble thinking of anything else nice to say about it. It's easier to load up with skis, snowboards & kayaks than the MPGiata?
4) Hate: reliability
Hate might be too strong a word -- it hasn't left me stranded (yet). But it's come pretty close.
- Fried wire between the starter & solenoid (but yay: it's light enough to push start pretty easily!); since repaired.
- Electrical glitch causing it to intermittently stall out/run rough (traced to a mystery bare wire shorting to ground against the pedal assembly).
- CEL codes:
(A) frequent P0455 for an evap leak
(B) P0400 for EGR -- I cleaned the valve, but it came back. Need to roto-rooter the passages, I guess.
(C) P0420 for catalyst -- this one popped up a few weeks ago. Hasn't come back since resetting.
Is it reasonable to complain about the reliability of a $1000, 20 year-old car? It's led a pretty charmed life - lots of care & maintenance from its 4-owner string of owners.
03-04-2019, 12:35 PM
#239 (permalink)
EBH - RIP
Last time I went to use the block heater, I noticed a lack of "spark" when plugging the cord to AC power. Confirmed inoperative by touch-test after left plugged in for a little while.
I haven't trouble-shot it yet. Could be plug (hopefully), could be element.
Fortunately (yay), spring is nearly upon us, so I'm not desperate to fix it.
The forecast shows the sap should start flowing next week (days above freezing, nights below). I had a great winter, full of fun activities, but I'm ready for it to be over now.
03-09-2019, 07:06 PM
#240 (permalink)
Aero Wannabe
- CEL codes:
Is the “Electrical glitch” the problem in this thread? https://ecomodder.com/forum/showthre...ing-36656.html
If so, care to elaborate/update for us?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
