09-15-2010, 11:34 AM
#111 (permalink)
Originally Posted by brucey
Pulley showed up today...
I hope this is just some misunderstanding on my part because otherwise it's an awesome piece of work. Looks like it will fit with a little heat pretty easily. Hopefully I will still be able to use this one.
sweet, that's rather beefy. Is it aluminum? If so be careful heating it...
09-16-2010, 03:09 PM
#112 (permalink)
A madman
Ordered a keyshaft that should be the right size. Along with a split collar to lock it all in palce.
Hopefully this should be it.
09-17-2010, 11:20 AM
#113 (permalink)
Basjoos Wannabe
Did the pulley fit on the shaft? I'm certain you know a precision fit will be extremely difficult to get perfect--if I were your pulley man I'd want the motor in my lap to get a precise measurement. Even if you both have good quality calipers, even .002 of a difference between the calipers will be problematic. and 2/1000th of an inch is very small. For a custom job, a measurement done on 2 parts with 1 good quality caliper is a billion times better than a measurement done with 2 better quality calipers.
 RIP Maxima 1997-2012
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
09-17-2010, 12:07 PM
#114 (permalink)
A madman
It looks like it will fit well. It is tight on there, in fact, so tight I'm afraid when I do mount it I'll never be able to get it back off. He suggested heating it at 300 degrees for 2 hours before mounting it to help it expand some.
It's pretty close to a perfect fit really. The shaft is 7/8" so I think that helped.
09-17-2010, 12:22 PM
#115 (permalink)
Basjoos Wannabe
if he said heat it to 300 then the snug fit must have been by design--a clever design really. A part with no slop would nearly never wear out!
09-17-2010, 12:49 PM
#116 (permalink)
A madman
I can actually put it on the shaft about .5" but then it's a pain to get back off. But just from that, I can spin the motor shaft itself quite quickly and even stop it without the pulley spinning. With the key rod in there and a collar on the end holding it all tight, I'm not going to be worried about it.
I'm hoping the belt has enough power to spin the motor up still, but I did get the pulley with 10 ribs in case I need more belt area. It should still work with the normal 5 rib I have however, I just have the option of upgrading if necessary (: Although I guess I'd have to upgrade the belt, the crank pulley, the PS/Alt pulleys too. Hopefully shouldn't be expensive if necessary.
I still haven't started on the wiring at all. I was wanting to get my block heater in and the teardrop finished before resuming work on this.
09-20-2010, 12:16 PM
#117 (permalink)
A madman
Just a quick update since I know there are some people waiting for this:
I had to order a split collar and a keyshaft to install the pulley. I know I should have done that sooner but well I forgot. The collar arrived 2 days after I ordered it, and the keyshaft still hasn't even shipped.
Bahumbug.
09-21-2010, 04:41 PM
#118 (permalink)
Basjoos Wannabe
grr, always hate waiting for parts.
But you know the adage, do you want quality, speed of service, or a great price? You can only pick 2.
09-21-2010, 06:40 PM
#119 (permalink)
A madman
I always thought it was sexy sane and smart. Pick 2.
09-21-2010, 08:23 PM
#120 (permalink)
I was only aware of Cheap, Reliable, Fast (pick two)
P.S. This thread is awesome. I'm excited to see where it takes you (hopefully a lot further on less fuel!)
