Old 01-20-2014, 11:02 AM   #1 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Electric Water Pump EWP80
Okay
We are familiar with Echo Troll(Canada) modifications. I have interest in the electric water pump . He went with a davies craig ewp80 electric water pump and installed in a TOYOTA. I am kinda considering modificiaton however have the following concerns:
space
mounting, mating , install in lower radiator space.
wiring connections.
do you remove belt driven water pump and if so how do you cover the new hole created.???
I like the idea of more engine torque and no belt but have concerns on how to get there..........
Old 01-20-2014, 01:43 PM   #2 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
i will try to answer some of your question:
space: my a/c delete helped me on my echo but what car you have?
you will receve wiring instruction and mounting instruction if you buy the ewp
i did not remove my water pump. what I did is remove the impeller
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 01-20-2014, 02:09 PM   #3 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Great thread idea. Subscribed. If there were a way to do this an make it reversible for emissions inspection, I would consider doing it. It's a great mod.
Old 01-20-2014, 03:28 PM   #4 (permalink)
40-60-40 MPH P&G
In my case it is not a reversible mod. But i dont Know why it Would affect emission ?
MPG=1 TIME=0
Old 01-20-2014, 03:38 PM   #5 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
+1 I've been wanting to do this since I saw echo-francis do it. Maybe this will give me the courage to do such a thing. (well, that and the money! )
I assume you mean not easily or worth the effort to have it reversed for an hour?
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 01-20-2014, 04:19 PM   #6 (permalink)
40-60-40 MPH P&G
to reverse it I would have to but a new mechanical water pump and 2 new water hose and it would be very PITA
MPG=1 TIME=0
Old 01-30-2014, 08:33 PM   #7 (permalink)
American Viking's Avatar
Dad's Jetta - '05 Volkswagen Jetta 2.5l package one
90 day: 23.23 mpg (US)
Black Cherry - '01 Honda VFR800fi
Last 3: 39.39 mpg (US)
Since Honda has discontinued a water pump design that fits about 500 of their motorcycles, and I went though hell finding one for a friends '97 vfr. After that 3 month crusade, I decided to look into replacing the Honda pump with something without a mechanical shaft seal.
I found that bosch makes a pump called the PAD pump that uses a mag coupled drive and only draws a few amps (less than the Craig pump). Its on my list of things to try on the HHO VFR, but its not at the top of the list.
JohnS
Black Cherry (no epa ratings)
Dad's Taxi
The Lead Sled (EV conversion coming soon)
Old 01-30-2014, 08:38 PM   #8 (permalink)
...beats walking...
Flow rate(s) vs. pressure(s)?
Old 01-31-2014, 01:02 AM   #9 (permalink)
I've got this chart, just remember most engine driven pumps don't move much water at idle.
JohnS
Dad's Taxi
Old 01-31-2014, 11:12 PM   #10 (permalink)
...beats walking...
...sorta *implies* the use / insertion of either: (a) metering plate/orifice or (b) adjustable value to control/limit coolant flow at engine idle, but not at full load conditions.
