Old 10-01-2008, 11:22 AM   #1 (permalink)
EOC Question
What is the shortest distance that you would bother turning the engine off for? I know that other traffic concerns happen, and things don't always turn out as planned. But, if you had the road to yourself.... what is the shortest distance you'd turn the engine off ?-- knowing you'd have to restart to climb a hill or accellerate.
Old 10-01-2008, 11:36 AM   #2 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
I don't do it much, but if i can coast down 20-30km/h in peace, then i'll turn it off. Also SOMETIMES if i approach a long light as it turns red i'll turn off if there is definately nobody coming. So it has more to do with time, than distance... If i can get a good 30 seconds of EOC, i'll do it.
Old 10-01-2008, 11:38 AM   #3 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
10 to 20 seconds is my minimum. Depending on the mood.....
ollie
Old 10-01-2008, 12:21 PM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Closer to 10 seconds for me. Maybe a little less. Depends if I can clutch start vs. key start (more likely to do short ones if I can clutch start).
Old 10-01-2008, 01:27 PM   #5 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I do pretty much what metro just said.
Old 10-01-2008, 03:34 PM   #6 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Nissan Altima GXE
90 day: 30.07 mpg (US)
if i will be starting with Clutch - as little as 10 seconds
if starting with Key - i try to keep it above about 20 seconds.
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Old 10-01-2008, 07:29 PM   #7 (permalink)
I try to get at least 6 seconds. I spend a lot of time with my engine off...
-soD
Old 10-02-2008, 12:15 AM   #8 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
10-20 seconds, but not as often as the past. The automatic is showing its age...
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
EOC and bad mpg... 97Cavalier Hypermiling / EcoDriver's Ed 10 05-05-2009 08:23 AM
'93 Geo Metro EOC question Newton Hypermiling / EcoDriver's Ed 9 09-19-2008 03:11 PM
Question about EOC with an Auto... :confused: LastBoyScout Hypermiling / EcoDriver's Ed 20 08-30-2008 06:28 PM
EOC fuel usage ?'s reformed EcoModding Central 4 06-12-2008 08:51 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 01:18 PM
