Old 03-06-2014, 11:23 PM   #21 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Charging 360V pack
Originally Posted by P-hack View Post
Interesting stuff in that EVTV vid (not just the packs).
They are going to have some charging challenges with those higher voltages.
Check here EVTV Motor Verks Store:
And scroll down to Configurable 4kW Charger
TCChargerModel: 208v 22A
258v 18A
290v 16A
389v 12A
Price: $1,895.00
So the TC Charger will go to 389 (may be a bit high? maybe not) at 12A or so.
I hope it works OK - I ordered one.
Old 03-07-2014, 10:33 AM   #22 (permalink)
Charging shouldnt be an issue in the US. I had my local power company tell me they can get me what I wanted up to 440 volts with its own line and meter.
Old 03-10-2014, 02:28 PM   #23 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
440-389 = buck away $50 later
Old 03-10-2014, 02:48 PM   #24 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
I was thinking of the individual cell voltages But line voltage is a consideration at some point too.
Old 03-10-2014, 06:53 PM   #25 (permalink)
rmay635703's Avatar
If its really cheap to have the right line voltage brought into your house (cheaper than a proper charger) you can eliminate a lot of components and dumb charge with an Ahr counter/cutoff and voltage cutoff.
A few folks do that using cap chargers, by the math they are only about 5% less efficient than a real charger.
Old 03-10-2014, 07:33 PM   #26 (permalink)
P-hack's Avatar
Yah, string charging is a lot simpler, dig up a suitable transformer if you have too. I was thinking of balance charging with an "odd" voltage per cell. Unless someone can reverse engineer the can protocol on it and/or the hardware on those packs...
Old 03-15-2014, 04:15 PM   #27 (permalink)
Not-as-good battery prices
The older CALB SE series, 100 A-h cells are on sale at EVTV for $1.00 per amp-hour. Elsewhere they are still over $1.30 per amp-hour.
About $312.50 per kw-h. A 24.3 kw-h pack would be 76 cells ... or $7600 ... not $3600 .. including the battery straps and washers.
Nominal pack voltage would be 250V in series, or 125V for 2 parallel strings.
For comparison, the CALB CA 100's are $150 at EVTV, $135 at EVWest.
They don't have the performance (higher battery sag under load, lower maximum current) that the CA series do, but I think they are .. sorta .. comparable to the Renault pack
