Old 12-10-2010, 12:09 PM   #241 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Ah, that's what I was looking for. Oddly, a 16" pizza pan fits a 15" wheel perfectly. I just wanted to make sure cutting them didn't lead to problems with it tearing apart or something from the rotation. Thanks guys! Plus this will fix the problem of snow packing into the wheels.
The Following User Says Thank You to brucey For This Useful Post:
Weather Spotter (12-10-2010)
Old 12-24-2010, 09:07 PM   #242 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by tasdrouille View Post
If anyone still had doubts on that one...
The chart is quite interesting. I tried a trip with clear packing tape on my wheels. Not sure what the difference was, as I didn't stop to do any A/B testing, but the tape did seem to help make the truck slipperier. Mileage was hovering around 20 mpg, even driving 70 mph 90% of the time. I did notice a lot of brake dust and dirt gathered behind the tape...
Unfortunately, I cannot easily find (21"?) pizza pans for 20" alloy wheels. I will probably buy some clear Lexan and cut disks for each. Found Regal Plastics here in OKC carries Lexan, ABS, and more. Still need a good method of attaching them, but the improvement to me is well worth the effort. I never got 20 mpg at 70 mph before...for nearly 500 miles.
The Following User Says Thank You to ECONORAM For This Useful Post:
backyard engineer (06-11-2011)
Old 01-03-2011, 02:50 AM   #243 (permalink)
Send a message via Yahoo to electric_ride
Originally Posted by Weather Spotter View Post
Mine do not come out to the edge (.75" gap) so I did not have to notch them at all. But the notch is a great idea if you only have one bolt.
Mine rattle when I hit bumps too. I tried some plastic tubing over the outer edge and it worked, till the tubing came off (broke epoxy).
So I am just living with the rattle.
I have been looking at this mod and love it. I understand about the rattle. Here are two what I feel really good options 1. tack it with 3M body trim glue maybe in a star pattern it won't take much or.... 2. put door edge molding around them. With the pressure of the wheel cover holding to the center cap they will not come off. Hope this helps. Anyone else with mod tips for a S10 please let me know as I am going to start modding my electric powered S10.
Old 01-03-2011, 10:42 AM   #244 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
For other tips, head over to our wiki mod page and look for other s10's. Other cars mods can work to.
Car MPG Efficiency Modifications Main - EcoModder
Old 06-11-2011, 10:45 PM   #245 (permalink)
your dilligence is very evident.thank you for sharing
Old 06-12-2011, 11:18 PM   #246 (permalink)
halos.com
Alright, a little update for you all. I am on version 2.1 of my wheel covers. I am now using unpainted black corrogated plastic, attached with parachute (550) cord laced around the wheel spokes. My center caps are recessed about 2-3 inches, so using Concrete's method won't work so well. I previously tried using self-adhesive velcro strips, but I kept losing a cover when I went over 65 mph. These stayed on at 85 mph, so I know 550 cord works... Just need to find something easier to remove.
Old 07-02-2011, 03:42 PM   #247 (permalink)
Big Bertha aka 2 Ton Tessi - '03 Dodge Grand Caravan SE
90 day: 20.4 mpg (US)
I have a 2 year old so I didn't have time to read the entire thread...thus I don't know if these were brought up... but I have a warning.
Some cars in some situations need that air flow to cool off the brakes. I know my 03 Grand Caravan would get really hot if I did this as they get hot as it is and I drive mostly in the city. So be sure to check the brake temp because the hotter they get the less they work and they will need replacing a lot sooner.
If your brakes get hot with this mod, I'd suggest replacing the entire brake assembly with one that's more for racing as they are bigger, disperse heat better and generally are much better/safer anyway. If it still gets hot, you will need to reverse the mod a little by making a few vents in the covers.
Old 07-02-2011, 03:48 PM   #248 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
as well as keep water off of the rotors.
Old 07-02-2011, 05:51 PM   #249 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The whole point of hypermiling is to stay off the brakes as much as possible, so it's not really an issue.
Are you sure they aren't sticking ?
If they aren't, change your driving style to avoid braking as much as possible.
Old 07-02-2011, 06:19 PM   #250 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
While heat may not buildup...it might.
Here is a thread I started on cooling front brakes:
http://ecomodder.com/forum/showthrea...kes-18011.html
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
