Old 08-02-2011, 11:28 PM   #21 (permalink)
Steven Wrigley's Avatar
Greenguzzler - '94 Ford F150
Last 3: 17.3 mpg (US)
I remember now what I was looking for in the garage one time... it was V8 4x4 pickups, of the sort 99% of the trucks around here are. IIRC NOBODY was averaging over 20 but there may have been a few odd 20 or 20+ tanks here and there, just like mine.
The bottom line is he can mod that thing, pour hundreds of dollars into it with "efi upgrades" and "tunes" and aerocaps and what not, the reality is it's a large thirsty beast and he ain't likely to break 20 mpg at all, and if by some small miracle he does, it will be juuuuuust barely.
Right If I can get around 20 or even 18mpg Ill be using alot less gas than at 11. Im not going to touch the engine or computer though.
Old 08-02-2011, 11:31 PM   #22 (permalink)
Good luck, you are going to need it.
Old 08-02-2011, 11:55 PM   #23 (permalink)
I take the impossible as a challenge! This is my inspiration. He got a 6mpg increase. My attempt at an aero cap... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2011, 12:18 AM   #24 (permalink)
Ah, youth, where they don't yet know that the laws of physics apply to them too. Yes, I remember those days.
P.S. 11 to 18 is a 64% increase.
11 to 20 is an 82% increase...
Old 08-03-2011, 12:36 AM   #25 (permalink)
Woops! That would be a huge increase. Usualy Im not this absent minded!
Old 08-03-2011, 10:54 AM   #26 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
What law of physics says you can't get 20 mpg out of a V8 4x4 pickup? I must have missed those classes.
I wasn't implying that 20 mpg is easy. I was implying that it's possible. And an 82% increase is going to take lots of work, but quite a few folks on this site run >80% over EPA.
Steven, here's a lesson for you (if you haven't already learned it): When somebody tells you that you can't do something take it as a challenge!
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 08-03-2011, 11:17 AM   #27 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Well, at least find out what the air/fuel ratios are and the timing protocols since they do have a great effect on mpg.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 08-03-2011, 11:47 AM   #28 (permalink)
Hmmm Ill look into that.
Old 08-03-2011, 11:49 AM   #29 (permalink)
If you applied that same 80% over EPA to a 35mpg rated car he'd be getting over 60 mpg instead of 20 mpg. The money savings from going to a car is huge. He already said he doesn't need a truck. The truck simply doesn't make any sense to modify, especially since he will have two of them.
The Following User Says Thank You to Daox For This Useful Post:
Frank Lee (08-03-2011)
Old 08-03-2011, 12:05 PM   #30 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
If you want to do it as a hobby, go ahead. It's not impossible.
But given the choices, I'd sleep on the bus and use the 16$ a day in gas I save and buy lots of beer.
