Old 08-31-2009, 07:26 PM   #1 (permalink)
toyota corolla - '99 toyota corolla ce
90 day: 38.97 mpg (US)
scam gadjet ?
hi , I found an item on ebay : F 16 PULSE KING FUEL SAVER- CE FC approved:eBay Motors (item 130320605463 end time Aug-08-09 19:01:57 PDT)
and in my research i found this : http://www.swmws.com/nap.pdf result on page 4
I want opinion please .
graphic:http://ecomodder.com/forum/em-fuel-l...vehicleid=3083
lowered -1.5 inch .
+80 pound (approximation) of audio (and draw a max of 20-25 amp approx..)(ouch for alternator !!)
Old 08-31-2009, 08:17 PM   #2 (permalink)
I think no one can answer me
lowered -1.5 inch .
Old 08-31-2009, 08:23 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
yanlapanic -
Sounds like the cheapy version of this (which also might be a scam, at least in terms of the magnitude of it's claims) :
Hyper Voltage System – by Sun Automobile :: Sigma Automotive
H.V.S. is an innovative new product for harnessing the full potential of your vehicle's electrical system. Sun Automobile debuted H.V.S. at the Tokyo Auto Salon in Jan, 2003 then again at the International Auto Salon in April, 2003. This latest device from Japan acts like a capacitor, except that it is used for performance rather than for audio applications. It's function is to stabilize the voltage of the battery so it is most effective when the battery is under a heavy load from components like A/C, stereo, lighting, etc. Where the same company's H.G.S. (a.k.a. Hyper Ground System) aids with the operation of the alternator, H.V.S. aids with the operation of the battery.
We have theorized that these are big "ultra capacitors" that level out the juice from/to the battery.
I got one of the cheapy versions a few years ago but I couldn't tell if it was helping.
Hrmmm, they are also selling the equivalent of the "nanopulser" battery desulfator :
This ...
F 16 Green Magic for 4, 6 or 8 cylinder cars:eBay Motors (item 130327684273 end time Sep-04-09 15:38:00 PDT)
Is same as this ...
Nanopulser :: Sigma Automotive
My opinion is it won't help your MPG in a detectable way, but it may help your radio reception.
CarloSW2
American Solar Energy Society
Old 08-31-2009, 08:49 PM   #4 (permalink)
Originally Posted by cfg83 View Post
yanlapanic -
This ...
Is same as this ...
CarloSW2
nice , this is a great information ...
but i could not understand how they get better mpg in there test and we can't ...
edit : thanks for the nice reply (added of link )
lowered -1.5 inch .
Old 08-31-2009, 09:04 PM   #5 (permalink)
ep3 dc5 hyper voltage stabilizer gas saver,power gain:eBay Motors (item 270445282064 end time Aug-27-09 10:48:49 PDT)
is it that cheapy one that you talk about ?
lowered -1.5 inch .
Old 08-31-2009, 09:12 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
yanlapanic -
Originally Posted by yanlapanic View Post
Not exactly the same, but definitely el-cheapo like mine :
CarloSW2
Old 08-31-2009, 09:15 PM   #7 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
yanlapanic -
Here's a URL that MetroMPG pointed out to me :
Fuel saving gadgets - a professional engineer's view
Where I am less convinced is when the claims are extended to significantly improved fuel economy or torque / power. Modern vehicle wiring and ECUs are already designed to operate in a harsh electrical environment. They cope with conditions from maybe 8V starting with a nearly-flat battery to 16V on a boost charge, and with electrical interference from mobile telephones etc, without failure. The ECU runs internally at 5V or even less and is heavily stabilised to ensure the processor runs fault-free at all times. Many modern ECUs repeatedly self-check and would shut down the engine entirely if any kind of fault condition occurred. Overall, it is hard to envisage how a more stable electrical supply could significantly improve engine economy, emissions or performance on a vehicle in good condition.
CarloSW2
Old 08-31-2009, 09:16 PM   #8 (permalink)
I think no one can answer me...
I think you're too impatient, to expect responses in an hour.
Easy. They make up their results :-)
Old 08-31-2009, 09:20 PM   #9 (permalink)
i make the second response because I know a lot of people don't know about it ..
an yes its a bit of impatience too
thanks for information ....
lowered -1.5 inch .
Old 09-01-2009, 09:36 PM   #10 (permalink)
sukisuki - '00 Suzuki Grand Vitara 4wd
90 day: 21.88 mpg (US)
Theoretically the voltage applied to the ECU and the spark plugs is the average voltage coming from the battery measured in place.
This can oscillate quite a lot depending where you are measuring it and if the alternator is charging or not and overall RLC of the car system.
Adding a capacitor to ground can help but I would do it locally like you place the decoupling caps close to the supply pins of an IC.
The Ethanol Scam: Are ethanol advocates giving slanted mpg numbers? Ptero Fossil Fuel Free 15 04-22-2010 09:58 AM
Do you smell a scam? RandomFact314 EcoModding Central 17 05-30-2009 04:08 PM
Home Depot Scam!!! ajax_6531 The Lounge 16 07-05-2008 05:34 PM
Newbee with hydrogen kit mechanic999 EcoModding Central 20 05-27-2008 02:17 AM
Scam or not?? Taco Bowl EcoModding Central 3 04-29-2008 11:48 PM
