Old 11-01-2020, 06:55 PM   #1 (permalink)
Fast warm up ideas: diesel fired air heater.
I got one of these.
It's a "5kw diesel air heater" they come in one's that look like this up to 8kw. Normally I say bigger is better but I went with the 5kw one because it can put out as little as 2kw of heat.
Looking at the 8kw heater I think you could only turn the heat down as low as 4kw. I just don't think I need to burn a tank of diesel at 13,000btu per hour. I would rather have more run time on a tank then heat output.
I'm thinking set it on top of the car, rolling down a window and running the heat in with a clothes dryer duct and that will melt all the ice off my leaf.
101Volts (10-29-2022)
Old 11-02-2020, 04:00 AM   #2 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Did you buy it for this purpose?
Would an electric heater have not sufficed? Or is there no power at one of your stops?
The Following User Says Thank You to Stubby79 For This Useful Post:
Old 11-02-2020, 02:43 PM   #3 (permalink)
When I leave from work in the morning after working all night there is no electricity where I park.
Oh and I think 5kw will be plenty to thaw out a car. Even the lowest setting should do fine on all but the coldest single digit mornings.
Or if I need to deice the car at home. When it gets down into the teens a single 1kw space heater doesn't do squat. So leaving a space heater in it over night just wastes that much electricity.
Old 11-02-2020, 03:53 PM   #4 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
The picture is small, but it almost looks like it needs electricity.
Old 11-02-2020, 04:27 PM   #5 (permalink)
Stubby79's Avatar
12-volt.
Old 11-02-2020, 05:53 PM   #6 (permalink)
Yeah it takes 12v.
Old 11-03-2020, 10:06 AM   #7 (permalink)
I'd take a look at the Webasto stuff before.
diesel, fast warm up, heater
