Old 11-22-2012, 11:13 PM   #41 (permalink)
MaxHedrm's Avatar
Golf TDI - '10 Volkswagen Golf TDI
90 day: 37.69 mpg (US)
I really need to update those mpg sites that I have in my sig. The Golf is at 39.5mpg lifetime & the last 6 months or so have been chipped and the last year has included to trips to East Texas for a driving course that isn't all that good on mileage.
Driven: 2010 VW Golf TDI
Driven less: 2001 Audi TT Roadster (225)
Parked: 1982 VW Jetta Diesel
Old 11-22-2012, 11:31 PM   #42 (permalink)
2012 VW Golf TDI 6MT
GaryTDI - '12 VW Golf TDI
90 day: 53.82 mpg (US)
Hey, at least it is currently higher than the sig. Are you seeing better or worse fuel economy with the tune (chip)?
Old 11-22-2012, 11:48 PM   #43 (permalink)
MaxHedrm's Avatar
It's dropped a little (maybe 1 mpg or so?) but I also got new tires about the same time that are a different brand and seem to be a different rolling diameter (even though they are the same numeric size). They are bigger around, so my car thinks it's not going as far (or as fast) as it is. The factory Continentals were spot on.
The Following User Says Thank You to MaxHedrm For This Useful Post:
GaryTDI (11-23-2012)
Old 11-23-2012, 12:04 AM   #44 (permalink)
Thanks for the info. My computer is reading 53.5 lifetime now so it's about 3 MPG or so higher than my current average so it looks like maybe your computer is reporting higher than you are actually getting as well. At least it isn't me :-)
Old 11-23-2012, 12:05 AM   #45 (permalink)
MaxHedrm's Avatar
Sounds like you do a much better job of behaving yourself with yours.
Old 11-23-2012, 12:18 AM   #46 (permalink)
It's become addictive driving efficiently since I bought this car which shocks the heck out of me because I've really only owned performance cars in the past. As you know this car is no slouch and that is exactly what I was looking for, a car that gets great fuel economy but is also sporty when needed. This car produced that in spades. I am so ecstatic that I own it. By the way, I also have a Shark Blue 2-Door :-)
Old 11-23-2012, 12:25 AM   #47 (permalink)
MaxHedrm's Avatar
Good taste.
Old 11-23-2012, 08:45 PM   #48 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by GaryTDI View Post
I just bought a 2012 Golf TDI in July and I'm curious if you are seeing the same thing I am with the overall fuel economy reported by the computer. Mine is reporting about 3 MPG better than I am calculating at the pump.
My computer used to be fairly accurate (like +/- 0.1 to 0.2 L/100km) with 0.1 being the smallest change that can be seen on the computer.
The + and the - tended to even out over time.
That is, until I really started hypermiling
(Coasting, shutting off the engine at standstill.)
Now it's usually - or rather always - on the optimistic side as well.
Up to almost 10% optimistic.
In mpg terms, that can mean an indicated 65 MPG, for an actual 59 MPG ...
The Following User Says Thank You to euromodder For This Useful Post:
Old 11-23-2012, 10:30 PM   #49 (permalink)
Thanks, that might explain it then because until recently I was shifting into neutral when going downhill and I have a lot of hills on my commute. I recently read that it might be better to keep it in gear and coast since it won't use any fuel at all while coasting in gear so I'm trying that so see how it compares.
Installing MPGino in 2002 Golf TDI dremd OpenGauge / MPGuino FE computer 55 09-28-2012 07:59 AM
6 speed swap in to my TDI Golf 4 dremd EcoModding Central 152 10-17-2011 05:17 AM
News: VW to unveil 70 mpg (US) Golf diesel hybrid MetroMPG Hybrids 27 06-29-2010 08:50 AM
Golf SE 2.0 TDI 140PS 6 Spd Carllongdriver General Efficiency Discussion 10 11-29-2009 04:31 AM
2003 Golf TDI Tires? Lostyankee EcoModding Central 6 09-18-2009 11:22 AM
